Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Strange Brown Screen of Death Problem, please help
Forum Homebuilt Systems : General Homebuilt - Strange Brown Screen of Death Problem, please help
I have a new build that I have been running about 2 months now without any major problems. I have only had one crash and that was only because my first OC was alittle unstable. Current OC is soild and runs Orthos for 12 hours without a single error.
Now to the problem. While gaming every now and then all of the suddon my screen turns like a bright muddy yellowish brown and I have to restart my comp.
I suspect it has to do with one of two things because it started right after these changes I made about 5 days ago. The first which I dont think causes the problem is I added a new PWM fan to the CPU cooler that alows for piggy backing a second fan so I have two fans running on one fan header. Then second which I do suspect because it started happening a few hours after I installed the Vista 64bit edition ESET Smart Security. I did unistall my old Norton security so it shouln't be a conflict of that unless it left traces behind. It also has only seemed to happen while online in a game giving me further reason to suspect it.
Has anyone heard of anything like this, weird brown screen crashes? I have no idea how to trouble shoot this problem and I don't want to contact ESET support unless I am positive it is directly related to the ESET software.
Sponsored Links
Try uninstalling the security software and see if the problem continues if you suspect that is causing the problem. Otherwize I would suspect buggy graphics drivers or other driver conflict
------------------------------ E8400 Wolfdale @ 3.6GHz || ZeroTherm NV120 || 4GB (2x2GB) G.Skill DDR2-800 4-4-4-12 || eVGA nVidia 8800GT || Gigabyte GA-X38-DQ6 || X-Fi Elite Pro || Samsung Spinpoint 1TB 32MB Cache/SATAII || 250GB WD Caviar SE || Seasonic M12 600W || 24" Dell 2407WFP @
Reply to agentsmith957
Uninstall ESET, if prbolem goes away thats it. If not reset your OC to default and test. How much OC are you doing and what kind of voltages?
Reply to roadrunner197069
did you thow poop on the screen? brown????? hmm...
------------------------------ Sealab 2021 season2:
What does thou mash and weep and scream crap?
Reply to jnava121
2 fans on one header may not give enough juice.
Check your temepratures, video card and CPU.
Try taking the side panel off and running the game with a fan blowing on the video card.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Thanks for the speedy replies.
If i uninstall the the ESET software should I be reinstalling the Norton trial since I have like 2 weeks left? I really don't want to be without internet security for a couple days and thats problay how long it would take to see if ESET was the problem, mabey longer because it isn't frequent. It's happened 3 times only since last thursday night, I installed ESET thursday afternoon.
If ESET were the problem would it be possible to fix it somehow? Since I purchased a years worth it would be a shame if I couln't even use it.
The OC isn't extream and has run flawless for almost a month now. 4000 Brisbane @ 2.8GHz and 1.40v, DDR2800 @ 2.2v
Reply to godsizesnakeyes
I know its not temps because I monitor that closely and everything is good. But would the CPU fan header not being able to give enough juice really cause a problem like I am having?
well, just want to throw in something about norton..
removing norton (all symantec products actually) will always leave some parts behind.. even the complete removal tool from symantec's site does not remove all parts of liveupdate..
Reply to michiganteddybear
Well thats just silly. You will survive a few days without the security.
If you are REALLY that worried, remove your computer from the network. You can still test your games....
------------------------------ EVGA 750i FTW ¤ Intel E8400 @ 3.6ghz ¤ EVGA 8800GTS 512 ¤ 2GB OCZ Platinum DDR2 ¤
Western Digital Raptor X 150GB ¤
MCSE, MCSA, Comptia A+ N+
Reply to rallyimprezive
I think I narrowed it down to having a second monitor hooked up. Could be a driver problem with my 3850 which would be just fine cause I don't really need 2 displays going anyway. Been going thru trial and error and it seems to be the culprit so hopefully I have it resolved now.
Thanks for the responses.
Sorry to bump this year old topic but I have the same issue.
My games crash to a brown or purple screen with infinite sound loops, forcing me to restart.
I have only 1 monitor with a GTX260 sp216, the game I play is Left4Dead downloaded from steam.
My GPU idles around 55-60'C and peaks at 78'C
Message edited by Bluescreendeath on 08-24-2009 at 04:27:06 AM
------------------------------ i7 920, E5300
GTX260, HD4870, HD4830
Reply to Bluescreendeath
bad input but.. BSD gets BrownSOD/PSOD
------------------------------ http://valid.canardpc.com/cache/banner/716209.png
Reply to jlear3
lol, yeh I actually haven't gotten the blueSOD in almost a year. :D
Message edited by Bluescreendeath on 08-24-2009 at 06:10:12 AM
hah none here since my corsair
Reply to jlear3
so can anyone pinpoint my problem?
bp
maybe the GPU doesn't like the downloaded game. Does it happen during a gpu stress test or any other games
Reply to tkgclimb
There are 577 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
