Tom's Hardware Forums » Homebuilt Systems » New System Build » $500 PC System Build (non-gaming + need everything) - HELP!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : $500 PC System Build (non-gaming + need everything) - HELP!
Profile: enthusiast
More Information
I have about $500 and I need everything...basically, I have no PC parts at all. So I need a case, ram, cpu, video card, motherboard, hard drive, cd-rom, psu, monitor, soundcard, keyboard/mouse, speakers etc. I would like the fastest and best pc possible for this amount of money and the fact I need to buy almost EVERYTHING.
I do NOT need an amazing/good video card...this is a NON-GAMING PC and I do NOT need an Operating System like Windows, I already have that. This PC will be for home application use mostly.
Can someone please make/post me the very best PC for around $500? remember this is from scratch, I need almost everything besides an OS.
Related Pr oduct
Profile: old hand
More Information
Best bet, go to tigerdirect.com, they usually have refurbished OEM machines like gateway, etc.  I have seen them in the 300 dollar range, then add a monitor.
http://www.tigerdirect.com/applica [...] CatId=2663
http://www.tigerdirect.com/applica [...] &CatId=170
PC was 349 I think, and Monitor is like 149 for 19 inch widescreen, should put you just over 500 with shipping.  I mean I don't think you'd beat that deal if you don't want to game.  If you do, look at the specs, but I think it has a PCI express slot so you can add a video card if you decide on some gamin later.
Profile: Eternal Poster
More Information
Profile: Faithful Poster
More Information
Better of buying a name brand and getting a warranty.
Profile: enthusiast
More Information
buy a dell.  see if you can get one through med/large biz that has Ubuntu preinstalled.  that way, you aren't paying for an OS.
Profile: enthusiast
More Information
Do you have to have a desktop?
Dell Vostro 1500 15.4" Notebook $399, Feb 12
http://www.dealsea.com/exec/j/4/?p [...] =1&afsrc=1
How cool is that!
Profile: enthusiast
More Information
  *All prices in Canadian dollars.
 *No additional duties or fees.
     DESCRIPTION  QTY  AVAILABILITY  UNIT PRICE  TOTAL
  L23-7245 :: Logitech X-240 3-Piece Speakers with Ipod/MP3 Player Dock (9.3 lbs)
         In Stock $48.99  $48.99
  L23-7050 :: Logitech EX110 Cordless Keyboard and Mouse (3.1 lbs)
         In Stock $29.97  $29.97
  H94-1911 :: I-Inc AG-191DPB 19" LCD Monitor - 8ms, 700:1, SXGA 1280x1024, DVI, VGA, Black, 300 cd/m², Built-In Speakers (14.2 lbs)
         In Stock $189.97  $189.97
  TSD-250AS6 :: Seagate Barracuda 7200.10 250GB Hard Drive - 7200, 8MB, Serial ATA-300, OEM (1.5 lbs)
         In Stock $69.97  $69.97
  † L49-GSAH55N CA :: LG GSA-H55N Super-Multi Security DVD ReWriter - 20x DVD±R Burn, 16x DVD±R Read, 8x DVD+RW, 6x DVD-RW, 10x DVD±R DL, 12x DVD-RAM, 48x32x CD-R/RW, Black, IDE (1.8 lbs)
         Ships within 24 Hours $31.99  $31.99
  P459-1236 H :: PCChips A13G+ Socket AM2 Barebone Kit - v3.0, AMD Athlon 64 3500+ 2.20GHz OEM, 1GB DDR2 PC4200, ATX Mid-Tower Case, 450 Watt Power Supply (20.5 lbs)
         In Stock $139.97  $139.97
Click  to remove the item from your cart.
To calculate shipping enter Postal Code:
   SUBTOTAL
S&H  Enter a Postal Code
TAX   ------
TOTAL      $510.86   With taxes....Best I could assemble.....
Hope this helps!
Intel C2D E6400 @2.5GHZ, Foxconn p9657aa motherboard, 2GB OCZ extreme platinum DDR2-800 rev.2 @980MHZ, Seagate320GBsataII 16MB HDD, BFG 7950 GT OC 512 GDDR3...
Profile: newbie
More Information
How about:
GIGABYTE GA-MA69VM-S2 AM2 AMD 690V Micro ATX AMD Motherboard = $60
AMD Athlon 64 X2 4200+ Brisbane 2.2GHz AM2 65W Processor - Retail = $64
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 = $46
LITE-ON BLACK SATA 16X DVD±R DVD Burner - OEM = $24
WD Caviar SE16 WD3200AAKS 320GB 7200 RPM SATA- OEM = $75
IN WIN IW-C589T.J350BFU2AD ATX Mid Tower Computer Case 350W Power Supply = $55
Logitech Value 100 Black PS/2 Standard Keyboard - OEM = $7
Logitech SBF-90 Black 3 Buttons PS/2 Optical Wheel Mouse - OEM = $5
Logitech S120 2.3 Watts (RMS) 2.0 Speaker System - OEM = $12
Acer AL1706Ab Black 17" 8ms LCD Monitor 270 cd/m2 500:1 - Retail = $150
Total = $498
The system g-paw put together uses the 690G chipset which has HDMI built in, and he includes a floppy, better speakers, faster DVD burner, etc. I think the In-win case looks better than the Rosewill, and there's a lot to be said for 320G of hard drive space.
You still get manufacturer's warranty by buying parts and putting it together yourself. Only that you have to do a little bit of self-support to figure out which part isn't working before RMA'ing it. You really don't want to send a part back only to have them return it saying it works perfectly :(
Add a reply
Google Ads
