Need some help
I am new to this, i have an inspiron 6000, everything is still runnin g really smooth since i bought it 2 years ago, but i have searched for hours on over clocking but have got mixed information, so i was hoping i can get help here, here is cpuz information, the entire file is attached
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Pentium M 740
Codename Dothan
Specification Intel(R) Pentium(R) M processor 1.73GHz
Package Socket 479 mPGA (platform ID = 5h)
CPUID 6.D.8
Extended CPUID 6.D
Brand ID 22
Core Stepping C0
Technology 90 nm
Core Speed 798.0 MHz (6.0 x 133.0 MHz)
Rated Bus speed 532.0 MHz
Stock frequency 1733 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 13.0x
max VID 1.308 V
Features XD
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01002001h
Max CPUID level 00000002h
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000006D8 0x00000816 0x00000180 0xAFE9FBFF
0x00000002 0x02B3B001 0x000000F0 0x00000000 0x2C04307D
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00100000
0x80000002 0x20202020 0x20202020 0x65746E49 0x2952286C
0x80000003 0x6E655020 0x6D756974 0x20295228 0x7270204D
0x80000004 0x7365636F 0x20726F73 0x33372E31 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x08006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00002020 0x00000000 0x00000000 0x00000000
Cache descriptor Level 2 U 2 MB 1 thread(s)
Cache descriptor Level 1 D 32 KB 1 thread(s)
Cache descriptor Level 1 I 32 KB 1 thread(s)
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x000001A0 edx = 0x00000000 eax = 0x00111488
MSR 0x00000017 edx = 0x00140000 eax = 0xD02486A6
MSR 0x00000198 edx = 0x06120D26 eax = 0x06000612
MSR 0x00000199 edx = 0x00000000 eax = 0x00000612
Chipset
Northbridge Intel i915PM/GM rev. 03
Southbridge Intel 82801FBM (ICH6-M) rev. 03
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 1536 MBytes
Channels Dual
Memory Frequency 266.0 MHz (1:2)
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 12
More about : question
so can this be overclocked with the pin mod? or with a program? as long as the pin mod has been test on this set up ill do it, but im not sure, i know very little, you guys probly have extensive infomation and experience thank you for help
Honestly, don't bother overclocking. While you can theoretically do it it won't be worth it with a pre-built system. A lot of the OCability comes from the mobo which you don't have a good one of, your chipset is trash for OCing and you can't adjust volts. I would never recommend a pin mod to anyone either. It is sort of one of those things that if you have to ask how you do it, you should never attempt it yourself, plus you won't have anyway to stability test beforehand so you run the risk of making your cpu worthless. There is a program that will let you OC in windows, the name escapes me right now, but like I mentioned earlier your mobo and stock cooling will make this pointless.
Overall, just don't bother attempting it with this comp. If you come back here with one that you built then we can help you out. Sorry if this seemed harsh but it is the truth.
Related ressources
Ask the community
