Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » Is 500W enough power for my system?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Is 500W enough power for my system?
Profile: member
More Information
My system specs:
3.0Ghz Wolfdale
Gigabyte EX38-DS4 Motherboard
8800GT 512MB
2GB OCZ Platinum DDR2-800 Memory
250GB Seagate Barracuda ES.2 drive
Sony Optiarc DVD-writer
I bought this power supply:
http://www.ocztechnology.com/produ [...] wer_supply
The system works fine at all default bios settings. The system fails post if I set the FSB to manual. I am confident all my other settings (SPD, voltages, etc) are fine, as the system works as long as the CPU clock control is set to auto or 333. Could the power supply be the issue?
Message edited by alpine18 on 03-06-2008 at 08:29:20 PM
Related Pr oduct
Your Local Canadian
Profile: enthusiast
More Information
It is plenty of power, when not on auto, you need to be pretty accurate with voltages for it to boot properly.  If you are off by too much it will crap out on you like you described.
Intel C2D E8400 OC @ 4.00GHz.--TRUE 120 W/ Scythe S-Flex 28.0dB.--EVGA 8800GTS 512MB.--ASUS Maximus Formula X38 (0907).--Crucial Ballistix 4x1GB DDR2 4-4-4-12 @ 890Mhz.--WD 150gb Raptor.--Corsair 620HX Modular PSU.--Antec P182 Case.-- Vista x64.
Profile: old hand
More Information
Agreed. I don't see this being a PSU issue.
Opinions are like asses,everybody has one.
Profile: member
More Information
I can manually set the voltages (1.9V DDR2 as memory spec, default CPU voltage, everything else set to auto), CIA2 disabled, 2.0 mem multiplier, all the standard o/c preparation stuff, and the system boots fine as long as the FSB is left at auto or 333Mhz.  With everything set the same, I can set the clock control to MANUAL and then change the FSB to 334Mhz, and the system will fail to boot. I've tried other FSB settings 332, 340, 350 - all fail. Set it back to 333Mhz and it boots fine.
Been tearing my hair out trying to figure this one out.
Profile: enthusiast
More Information
it looks like memory problem insteads psu problem, when you set the FSB to 334, what is you memory speed? if you set memory to 1:1 ratio, it is only 668, way below the 800, if you oc the memroy over 800, it may required more voltage or loose timing.
Add a reply
Google Ads
