Tom's Hardware > Forum > Motherboards & Memory > MSI-Microstar > MSI mobo bootup problem
Forum Motherboards & Memory : MSI-Microstar - MSI mobo bootup problem
Hi, I seem to be having some mobo troubles. I have a 865PE-Neo2-p msi mobo with p4 2.8 HT processor (478). Well the other day it wouldnt boot into windows nor could I get into the bios. It was stuck at checking nvram, never succeeded or failed. I got tired of that and I then walked away. Next day it happened again so I started trying some things. First I reseated the ram, swapped out different ram, swapped out a power supply, reseated video card, and finally pulled the battery off the mobo to reset. Now when I boot up, i have a splash screen with the msi logo and pentium 4 logo and it never goes past. I get the initial beep when booting it up but then I get two beeps with a slight pause followed by a single beep and the d bracket has the following lights. Both the top lights (1,2) are showing red, the bottom left (3) is showing green and the bottom right (4) light is black. I have checked the codes and beeps but cannot figure out what the problem is. Any help would be appreciated. Thanks
Sponsored Links
There are 651 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
