hi all,
i just bought a couple of WD 1Tb green internal hdd wd10eads which i connect to laptop through external casing and am facing the following problems:
1. Even after fresh partition creation & formatting, when I do a scandisk(right-click-check now in vista) they have some errors like 'security processors' error when they try to fix for me, but after fixing when i run it again.. the same problem occurs, it never gets fixed? i used disk management to create the partition & formatting.
2. when i am copying data between the two same harddisks through external casing.. after copying a few files, there will be a 10-20sec pause before the copying continues.. then the 10-20 sec pause repeats
3. when i try to download the diagnostics tool fr western digital website and run it, it doesn't allow me to check my hard disk through the external casing, it categories my hard disk under \logical drive\ and only allows scanning of 'physical drive\ which is my laptop hard disk
4. the hard disk takes very long to be detected after i plug in the external casing and each scan disk always manage to find things to 'fix\ about it, which actually deletes my data to found.000 ( most of which cannot recovered).
the hard disks are relatively new, most prob. not hardware prob.. help pls
any help on any of the above issues will be greatly appreciated ...
