I've tried to make some builds but i keep going over the budget or making some stupid mistakes
The budget is somewhere between 600 and 800 Euro's so in dollars: $880 and $1173.
Its not for gaming, so no next-gen vid card or sound card is required. It has to be fast though, I was thinking of a Core 2 Duo e8400 or maybe something a lillte less. 2 - 4 GB of RAM, 250 - 500 GB HDD or so it depends on the other costs.
Total is 680USD, and should be very capable of running any modern softwares. Hope this helps.
------------------------------Intel will not take the top spot, or probably the top 3 spot back for the forseeable future. Not even with 32nm and more cores will intel be able to beat Jaguar. - JennyH the AMDiot, Nov 2009
Reply to yomamafor1
The mainboard is it compatible with the e8400 (45nm) cause I can't find that anywhere.
And i've read some bad reviews on the tower. But overall thanks for the build suggestion it'll help me out big time
