Just got the new CPU/Mobo/RAM that is below and I'm having a couple problems. The major one is that since I installed this setup 3 days ago vista has hung up 4 times. It seems to happen when I have mozilla open and everything freezes for 30 seconds and then comes back (sometimes). I just had to do a hard restart and the primary drive where my OS is installed did not show at post and I got a Error Loading OS. Had to turn off completely to get it to show back up.
I did prime95 test for 3 hours yesterday with no errors so I'm inclined to think it's either a board or HDD problem. My Hard drive is probably 3 years old now, it's a WD Cavier 250GB which has had at least a dozen reformats since I got it. I'm also using an older Enermax Noisetaker 485W PSU using 4 to 8pin power adapter. I had it on my old AMD X2 build for 5 years without trouble and was hoping it would be able to power this system. I did however make the mistake of changing the HDD BIOs setting from IDE to AHCI AFTER I installed vista, could this be the source of the problem? Would a reformat or repair be a possible solution? I'm running 2 other drives a 500GB sata and 120GB IDE and Bios has been flashed to new version.
My second problem which is more of an annoyance than anything is that when I select Shut Down in vista it goes threw the shutdown screen and HDD's turn off, however the case and cpu fans keep running and won't shut off until I hold the power button down. I dunno whats happening here, I have the board set to Smart Fan Control - Auto and one of my fans is using a Zalman speed controller. They're all hooked into the board including the VGA Fan. Any thoughts? Vista Power settings are at "High Performance" as suggested by another forum. The temps are within norms cpu 25-50C, chipset 40-45C, HDD 50-56C, GPU 47-60C.
Thanks in advance everyone
-Ray
Intel Core 2 Duo E7400
Gigabyte EP45-UD3R P45
G-Skill 4GB DDR2 1066
XFX 9800GT 512MB
Windows Vista Ultimate x64
Message edited by mentalcrisis00 on 03-14-2009 at 07:56:48 PM
