News
Built-in 3/3.5G may be next big thing in notebook market
Published on December 08, 2006
Communications chip suppliers are eying the huge business opportunities promised by notebooks with built-in 3/3.5G modules. Read more
Michigan Frat House Builds Paintball-firing Panzer Tank
Published on April 07, 2008
Flint (Michigan) - A 19-year-old Kettering University student and his frat brothers have built a working Panzer tank. Read more
ADSL routers with built-in WLAN modules to account for 60% of global shipments in 2006
Published on June 29, 2006
Of the total global shipments of ADSL routers in 2006, the proportion of those with a built-in wireless LAN (WLAN) module is expected to climb to 60% by year-end, up from about 33% currently, according to sources at WLAN chipmaker Broadcom. Read more
CeBIT 2008: DFI's High-End Under The Spotlight
Published on March 10, 2008
Well known among overlockers, DFI showed its latest board built on a X48, nForce 790i (C73 + MCP55) and AMD 780 (RS780D +SB700). Here are well designed boards with two PCI 16x slots (except for the ADM card), digital power supply stage at 8 phase (which makes sure there isn't any voltage drop when the processor's in peak), capacitors using solid electrolyte and a Thermalright cooling system. In other words, we have the best components for overclocking. Read more
Latest Reviews & Articles
Gaming Effects Versus Hollywood, Part II
Published on November 12, 2008
How far are PC graphics away from reality? Tom's Hardware takes a second look at the effects and tricks used currently by game developers to achieve more realism than ever before. Read more
Quick Takes: 13 Mid-Tower Cases Rounded-Up
Published on November 11, 2008
Functionality, elegant design, and solid build quality characterize these mid-tower cases. They offer enough space for several hard drives and graphics cards, making them the ideal foundation for enthusiasts. Read more
Best Video Cards For The Money: Nov '08
Published on November 10, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, though, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Power Supply Roundup: Part II
Published on November 07, 2008
In Part I of our power supply roundup, we went through five mainstream PSUs rated at up to 700 W. Round two sees us tackle another seven mid-range units in an effort to determine which power supply deserves your attention. Read more
  Tom's Hardware Forums » Overclocking » General Discussions » New Overclocking Built Please Help
Word :   Username :
Bottom
Author
 Thread : New Overclocking Built Please Help
Profile: stranger
More Information
I'm trying to build a computer with mass overclocking
I have read a review on the cpu that it can be overclocked to maximum of 4.0ghz
Please help me with the parts. If they are eligable for mass overclocking.
Maximum bugdet of $700.00 is what i can afford.
Maybe a Cheaper Computer Casehttp://en.wikipedia.org/wiki/Computer_case can be better.
Please Help
COOLER MASTERcooler master RC-690-KKA1-GP Black SECC/ ABS ATXatx Mid Tower Computer Case Real Power Pro 550W Power Supply
Case:Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811129021
$149.99
-40.00
$109.99
Arctic_Silver 5 Thermal Compound
http://www.newegg.com/Product/Prod [...] 6835100007
$5.99
Memory:G.SKILL 4GB (2 x 2GB) 240-Pin DDR2ddr2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model F2-8000CL5D-4GBPQ
http://www.newegg.com/Product/Prod [...] 6820231145
$114.99
-40.00
$74.99
MotherBoardmotherboard :GIGABYTE GA-EP35-DS3L LGA 775 Intel P35 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813128337
$89.99
-5.00
$84.99
CPU:Intel Pentium E5200 Wolfdale 2.5GHz LGA 775 65W Dual-Coredual-core Processor Model BX80571E5200
http://www.newegg.com/Product/Prod [...] 6819116072
$89.99
CPU Cooler:ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835233003
$36.99
VGA:HIS Hightech H485QS512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported IceQ4 Video Card
http://www.newegg.com/Product/Prod [...] 6814161243
$194.99
PSU: PC Power & Cooling Silencer PPCS500 500W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817703015
$89.99
-10.00
$79.99
Message edited by dongpane on 09-16-2008 at 06:52:35 PM
Related Product
How could I go from the king of RockN'Roll to this
Profile: old hand
More Information
First of all you didn't do your links right. Also, reaching 4GHz is going to be a little difficult with just air cooling. Now then your CPU is going to have a 200MHz bus quad pumped to 800, so it has a multiplier of 12.5. In order to reach 4GHz your going to need to raise the FSB to about 320, or 1280 in quad pumped Intel terms. That being said your MB can handel a quad pumped FSB of 1333 just fine so the limiting factor on your MB will be how much voltage it will allow you to push to your CPU.
Your RAM should be just fine. You could probably get away even with DDR2 800 RAM if you run it 1:1 with the FSB which would give you a DDR Ram speed of 640, assuming your CPU makes it to 320 FSB anyway. While the Thermal Silver will definitely help you mighnt want to consider an all copper cooler. Such a cooler would be more expensive though. Check out cooler reviews and the overclocking section here to find the best cooler, but if you really wanna break 4GHz I really recommend going with some kind of liquid cooling.
Message quoted 1 times
Message edited by Megamanx00 on 09-11-2008 at 10:22:34 PM
Don't give up. Visit votenader.org Athlon 64 X2 5000+| Brisbane | GIGABYTE GA-MA790X-DS4 | 2GB Mushkin DDR2 800 | Plextor 760A| Asus EAH3850 TOP/HTDI/512M | WD 200GB| Fortron Blue Storm II 500W | Creative Audigy 2| Win XP Pro & Vista Buisness 32bit
Profile: Eternal Poster
More Information
You should hit 4.0 if you can keep it cool.
It would be easier on a P45 though. More stable and more options.
Sniper
Profile: Forum Fixture
More Information
^+1.
Don't forget to check out:
GUIDE: Overclocking On P35-DS3L
One more thing. DO NOT get DDR2 1000 RAM. They have problems with the P35-DS3x line of boards. Get regular DDR2 800.
Also swap cooler to XIGAMTEK S1283 (+ bolt in kit). Good PSU, CPU,etc.
Message edited by Shadow703793 on 09-12-2008 at 09:01:30 PM
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
You tell me what I do.
More Information
Megamanx00 wrote :
...reaching 4GHz is going to be a little difficult with just air cooling.....
i STRONGLY disagree! you can reach 4Ghz on air with the new 45nm Core 2. its even can reach 4.2Ghz on air as well.
OP: the ACF7P cant reach 4Ghz i can tell you that. get a normal DDR2-800 and OC to 900Mhz(FSB450) and with the CPU using 9x multiplier you will get 4Ghz.so basically what i tell you is:
9x450@4Ghz 1:1 memory@900Mhz@(preferably)2.1V@4-4-4-15.i think most ram can reach this kind of speed in my experience and knowledge.
+1 on the Xigmatek Core Contact Freezer its better then Xigmatek cooler.
My name is... V3NOM... and i like cheese.
Profile: nimble knuckle
More Information
xigmatek core contact freezer LOL! bet iluvgillgill all (hehe counter strike source :P) that he meant sunbeam.
More Information
yep!the SCCF!!!
top rank cooler:
TRUE
SCCF
Xiggy S1283
Google Ads
