Problems W/ Ram
Word :   Username :
Bottom
Author
 Thread : Problems W/ Ram
Profile: journeyman
More Information
Ok I have this board http://www.newegg.com/Product/Prod [...] 3131517and it has worked well for some time and i am using these other parts:
http://www.newegg.com/Product/Prod [...] 6819103531
http://www.newegg.com/Product/Prod [...] 6820144112 (x 2)
http://www.newegg.com/Product/Prod [...] 6814130062
So had it set up and working for some time. Then I decided to make a new PC, and take some parts from it - the HDs and PSU and make a new system. Well i ordered a hd and a psu for it to have two systems. It was working fine but i think the hooks for the ram slots might have come loose. I know if you are using two memory sticks they have to be dual channeled. I put two memory sticks one in a1 and one in b1 and get no post at all. I put one stick in b1 which is what you do if u are using a solo stick - no dual channel and it works fine. The ram appears to be fully in its slow and doesnt seem to feel loose. I am not sure what the problem might be. I got the manual and can upload it somewhere if needed. (its over 7mb)
Well I have tested the Ram and the video card in another system and they both worked fine.I really assume the CPU is fine too.
Message edited by ukbsktbll on 04-04-2008 at 07:38:02 PM
Google Ads
News
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Microsoft fixes critical IE problems
Published on December 14, 2005
Microsoft this week fixed a widely reported flaw in its Internet Explorer browser that had been used by attackers over the past few weeks to take over the PCs of unsuspecting users. Read more
E-voting worries focus on failures, not fraud
Published on November 10, 2006
Major electronic voting machine problems occurred in at least six U.S. states during the country's midterm elections, underscoring that system failure, not fraud, is the biggest issue facing future races, voting-rights activists and technologists said this week. Read more
Microsoft patches 20 security holes in February update
Published on February 14, 2007
Microsoft's monthly security update for February has gone live. Though it marks the first update since the consumer release of Windows Vista, none of the 20 fixes are for the new operating system. Read more
Latest Reviews & Articles
Part 4: Avivo HD Vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
