Tom's Hardware > Forum > Homebuilt Systems > New System Build > My new build system-PSU question
Im planning to build a core 2 quad Q6600/Q9450@P35 MB,2gb ram,8800GTS 512,2 x 500GB HDD@RAID,2 DVD-RW.
Im looking to overclock the CPU to about 3.6Ghz and also overclock the 8800gts to its max the ram would be running at about 800-900mhz.so how much power do i need for this system?would 500W be enough @ peak usage?thx in advance
Sponsored Links
I think 500 is cutting it too close. I ran your spec'd system through the eXtreme Power Calculator and came up with 465Watts. Data used:
High End Desktop / 85% TDP / Q9450 @ 3.5Ghz Vcore 1.4 / 2GB DDR2 @ Stock
8800GTS G92 512MN @ Stock/ 2 SATA HD / 2 DVD+RW / 3 USB devices
3 120mm case fans (2LEDs) / 90% system load / 20% capacitor aging
Throw in the CPU cooler fan, the GPU overclock, possible future upgrades to 4GB RAM, maybe a Blu-Ray drive, another HD and a few other items and I'd suggest going with a good PSU in the 600Watt range.
Message edited by WR2 on 02-17-2008 at 08:26:16 AM
Reply to WR2
Something along the lines of a Corsair HX520 or similar would be more than sufficient, just make sure it's a quality 500 watt unit not a crappy Rosewill type.
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
- 0 +
/\ agreed. Just make sure you get something a little over 500W, Corsair HX 520W or the OCZ GameXstream 600W should be enough.
------------------------------ GA-965P-DS3 Rev.2 (F7) | E6300 @ 3.0 (429*7@1.325) | Arctic Cooling Freezer 7 Pro | eVGA 8800 GTS 640 MB | OCZ 600W GameXStream | 2X1 GB (2GB) Crusial Ballistix Tracer w/LED (4-4-4-12) @ 2.1v
Reply to CmdPT
Here is what result i got from the wattage calculator.thanks to WR2:) what amp@12V would you recommend?
System Type: Single Processor
Motherboard: High End - Desktop
CPU: Intel Core 2 Quad Q6600 G0 2400 MHz Kentsfield
Overclocked: 3600 MHz, 1.5 V
CPU Utilization (TDP): 100% TDP
RAM: 2 Sticks DDR2 SDRAM
Video Card: NVIDIA GeForce 8800 GTS 512MB
Video Type: Single Card
SATA HDD: 2 HDDs
DVD-RW/DVD+RW Drive: 2 Drives
USB: 3 Devices
Front Bay Card Reader: Yes
Fans
LED: 3 Fans 120mm; 2 Fans 250mm;
Keyboard and mouse: Yes
System Load: 100 %
Capacitor Aging (+ W %): 15 %
Recommended Wattage: 607 Watts
Reply to iluvgillgill
- 0 +
First off I don't think that the CPU will hit a voltage of 1.5V thats maybe a little too much. Another thing you won't hit CPU Utilization (TDP): 100% TDP.
Reply to CmdPT
Corsair 620HX = job done. That wattage calculator a) overestimates & b)is sponsored by companies that want you to buy overpriced, overpowered PSU's.
The Enermax Infiniti 720W will give you a little more room to grow, its modular as well.
ENERMAX INFINITI EIN720AWT ATX12V/ EPS12V 720W Power Supply 100 - 240 V RoHS - Retail
http://www.newegg.com/Product/Prod [...] 6817194021
------------------------------ Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Reply to systemlord
alright.but what amps am i looking at?
- 0 +
Any good quality PSU you get should have enough or plenty of amps to run you're system fairly well.
Reply to CmdPT
- 0 +
The PSU calculator takes a SWAG at the size of PSU and not the actual power draw of an proposed system.
It's true the PSU calculator overestimates a bit, but on the other hand people tend to underestimate how much stuff they'll end up wanting to run off the PSU. A 3rd HD, another 2GB RAM, a Firewire camera or a couple more USB devices, maybe a TV tuner card and a Blu-Ray drive or a NextGen GPU, etc.
I couldnt find anything about what a max OC'd 8800GTS/G92 draws. I'd suggest 50amps +12volts is in the ballpark - more than you'd need now, probably enough for modest upgrading. But if you think you'd want to load up your system a bit more like what I mentioned above it wouldnt hurt to look for 60amps.
Corsair 620HX = 50Amps $145 after rebate
Enermax Infiniti 720W = 56Amps $170 after rebate
PC P&C Silencer 750 = 60Amps $170 no rebate & free shipping
OCZ GameXStream 700 = 50Amps $100 after rebate
Corsair 750TX = 60Amps $150 after rebate
i
Reply to WR2
Nowhere near close. 2 8800GT's + 5 HDD's + 5 case fans + 90nm 939 x2 CPU + 4 USB devices + DVD/RW does not even come close to putting a 620HX under load, so a single 8800GTS is going to be nowhere near 50 amps, sheesh.
50amp on OC 8800gts?are you sure its this much?i dont think a single rail provide that much of amp.
- 0 +
$65 shipped after $15 rebate and will easily power any non-SLi setup:
http://www.buy.com/prod/corsair-vx [...] 52646.html
Reply to Noya
Nice.
- 0 +
I never said a 8800GTS would draw 50amps. I only said I couldnt find its draw at max OC.
A 8800GTS/G92 only takes ~120watts at full load @ stock or 10amps. A max OC? Take a guess.
Q9450 95watts at stock. TDP is 130watts and thats about what you get from a Q9450 @ 3.6Ghz 1.3vcore from the eXtreme Power Calculator. Thats about 12.5amps. Maybe 25amps total for just the OC'd CPU/GPU?
50Amps is what I recommended for total +12volts. And I did say it was more than you'd need with the items you listed. Which is what mousemonkey's 620HX has - 50amps total +12.
edit; with 75watts through the PCI-e slot and 75 watts available through the PCI-e connectors the max you can provide to the 8800GTS is 150watts or 12.5amps.
3870X2 takes 188watts under load @ stock which is why it has the PCI-e x6 and PCI-e x8 connector power slots. 15.5Amps @ stock.
Message edited by WR2 on 02-17-2008 at 06:26:40 PM
Reply to WR2
- 0 +
mousemonkey wrote :
Nowhere near close. .
50Amps of +12volts has to be pretty close - its what you recommended to the OP with the Corsair 620HX.
Reply to WR2
My apologies, I missed the full stop and assumed you were referring to just the GPU not the total system.
There are 670 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
