Tom's Hardware Forums » CPU & Components » Sound Cards » What sound card should i get? creative or Auzentech
Add a reply
 Word :   Username :
Bottom
Author
 Thread : What sound card should i get? creative or Auzentech
Profile: old hand
More Information
im currently using the sound card that came with the asus maximus formula but i want to upgrade. Im not sure which to choose because each card seems to have some major flaws like lcd panels... (shudders)
auzentech$199 (on sale for $140) prelude- http://www.ncix.com/products/index [...] omoid=1020
creative$100- http://www.ncix.com/products/index [...] ive%20Labs
creative$185- http://www.ncix.com/products/index [...] ive%20Labs
creative$170- http://www.ncix.com/products/index [...] ive%20Labs
i am leaning towards the auzentech because i have heard good things. However supposedly there are MAJOR driver issues. for example this one guy left his pc on for a week and the sound card ate up 800mb of ram... (ram leak or something, a simple reboot solves but still very annoying)
im on xp mostly but i also have vista on my other hard drive. any advice?
Message quoted 1 times
Message edited by maverick7 on 03-13-2008 at 03:09:42 AM
Related Pr oduct
Profile: old hand
More Information
ok i just read another review on the auzentech preulude and the drivers are supposedly really messed up, does anyone have any experience with any of these cards?
Profile: addict
More Information
Profile: old hand
More Information
? lol
Profile: old hand
More Information
He means that the sound card itself is an amazing peice of technology, but much like the HT Omega, the driver support and implemention are said not to be there. I am new on the subject as well so I am not totally sure, but I see the same thing a lot. Do not get a Creative Labs sound card, though I love the company, you will need and must have sp/dif coax, especially if you are paying those prices.
Profile: enthusiast
More Information
I have an Auzentech card, and an HT Omega.
The HT Omega works fine, and I've heard good things about their support ALTHOUGH I have no first hand experience of this. This in itself is a GLOWING endorsement.
Auzentech. Product pretty good.
Customer support. Terrible. I dealt with them on and off for 4 months as they failed to resolve an issue I had.
I think if the product works out of the box with Auzen, you're ok.
TBH, I will probably buy a prelude in the next six months.
GA-X38-DS4 (BIOS F3)||E8400 C2D (3.6GHz)||2*1Gb Crucial Ballistix DDR2-800 4-4-4-12||320Gb WD Caviar||Cooler Master Real Power Pro 750W||8800GT 512Mb||HT Omega Striker 7.1
Profile: addict
More Information
Curve ball into this thread...
(Especially as I am leaning towards a Auzentech Prelude as my Auzentech Xplosion has s*** Linux driver support.)
But have you considered:
http://www.bjorn3d.com/read.php?cI [...] ageID=2645
http://www.elitebastards.com/cms/i [...] mitstart=0
Someone else brought this up on another thread... Driver support looks good.
I am intrigued as they have some Linux drivers to download (thats for my benefit I should add!!)
Bob
Message edited by bobwya on 03-13-2008 at 05:21:28 PM
Plays with his WEI
Profile: Honorary Poster
More Information
I have an Auzentech Prelude running on Vista 64 - It works great, and sounds awesome. Actually bought a new surround stereo for the house (was planned for later this year) so I could move the old one to my office because the card sounds *that* good on it.
About all I would say is to not use the drivers on the supplied CD. Rather download and use the latest from the Auzentech site, as there is new functionality.
The more I read the forums, the more I feel that a number of individuals would be well served by skipping their next GPU purchase in favor of a little "Stress relief" from the local 'Working Girls'"
Profile: enthusiast
More Information
Sailing in my Dreams
Profile: Forum Veteran
More Information
I have a Creative Fatal1ty Platnum and it works rather well. One reason I like it better than the Auzentech is the front panel, which makes it easy to plug in headphones, fine tune adjustments, etc. And Auzentech has bad tech support, so-so drivers, and I think its a bit overpriced for what it is.
One last thought, unless you have really good speakers, you probably won't need cards quite as high priced as the Fatal1ty Platnum or the Auzentech Prelude. Good speakers benefit from these cards, but cheap speakers still sound like cheap speakers.
Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
Over 50. Seen it, done it, can't remember it.
Profile: member
More Information
X-fi on my current Asus Maximus formula it works fine under vista. Ignore the fact it has no linux support ;). That isn't a sound card what your running by the way, its more of a sound amplifier.
Profile: member
More Information
I got a x-fi xtrememusic on one pc and a x-fi xtremegamer fatality on the other pc. Both are running vista 64 Ultimate atm with no problems under latest creative drivers.
The only reason why i would recommend the Auzentech X-FI Prelude is if you have an amplifier and some very good 5.1/7.1 speakers that you will connect via optical or coaxial.
Other than that, go for one of the 2 X-FI's i mentioned (though i think the XtremeMusic is discontinued)
Profile: member
More Information
I'm loving the Auzentech Prelude in my new system. My speakers sound so much better than they did with my last soundcard (a soundblaster audiology)...it's incredibly noticeable. I haven't ran into any problems that couldn't be corrected by a noob such as myself and I highly recommend the soundcard...at least for 64-bit Vista. I can't comment on using it with any other OS.
Antec P182SE, Seasonic M12 700W, EVGA 780i, Noctua NH-U12F, E8400, 150 GB Raptor, 500 GB WD Caviar, 250 GB Seagate, 2 LITE-ON DVD Burners, AuzenTech X-Fi Prelude 7.1, 8GB G.Skill RAM, EVGA 9800 GTX, Hanns·G 28" Monitor, 64-bit Vista Ultimate, Z-5500's
Profile: enthusiast
More Information
well i think the prelude has every thing of a xfi card and a little more because it supports dolby digital live and the prelude has better capacitors and people claim they have good tech support.
i dont own a prelude i have a creative xtreme gamer fatallity platnium
at newegg the xtreme gamer fatality is 85 after rebate
http://www.newegg.com/Product/Prod [...] 6829102005
if i could i would go with the prelude but the fatality extreme gamer is the best bang for your buck if you get it from newegg
the creative platnium card and the xtreme gamer fatality are the same. i had both of them and the only diffrence with the platnium card is the io drive and remote which i never use and the remote is cheap.
i think of the prelude as a HT Omega Claro and a xtreme gamer fatality in one sweet package
Message edited by cal8949 on 03-13-2008 at 09:24:12 PM
Profile: stranger
More Information
As has been mentioned the Prelude is the card to get if you are planning to connect it up to a proper 5.1/7.1 system over SPDIF (Coax / Optical), its what the card is designed for. If all you are planning to do is connect the card up via old style analogue cables then just get the Fatality, as you will largely be wasting money on functionality that you don't need.
The other option if you are after SPDIF solution that is gamer friendly is the Asus Xonar D2X, as that now has EAX 5 support. Its usually about the same price as the Prelude.
Add a reply
Google Ads
News
Creative Finally Launches True X-Fi PCI Express Parts
Published on May 19, 2008
  It took some time, but Creative Labs has finally introduced decent sound cards for PCI Express interface. Read more
Creative announces 2 megapixel webcam
Published on March 16, 2007
Creative announced what the company calls the "most advanced webcam on the market". Read more
Asus XG Station Approaches Availability
Published on January 13, 2008
Announced around a year ago, Asus' external graphics enclosure is nearly production ready, according to company sources. Read more
AMD brings X1900 graphics to the Apple Power Mac G5 Quad
Published on November 07, 2006
AMD has announced the ATI Radeon X1900 G5 Mac Edition, a next-generation graphics card that combines workstation-class creative productivity and cutting-edge 3D game performance, according to the company. Read more
Latest Reviews & Articles
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
