Tom's Hardware > Forum > Graphic & Displays > Nvidia > How can you spot the difference between GDDR2 and GDDR3?
Forum Graphic & Displays : Nvidia - How can you spot the difference between GDDR2 and GDDR3?
I just bought a computer and I'm not sure if my graphic card (nVidia 8600GT) has GDDR2 or GDDR3. Is there a way to see/read which type has it? Some program, (like RivaTuner, SiSoft Sandra, 3DMark ...), the card's BIOS (how do I enter the BIOS?), anything else ....
Sponsored Links
GPU-Z
And the 8600GT has DDR3.
Message edited by hawkspur on 02-25-2008 at 09:22:45 PM
------------------------------ Asus Maximus Extreme : 2x Sapphire HD 3870 in Crossfire 850/1126 : QX9650@4.2Ghz : 2GB OCZ Platinum DDR3-1600 : PC Power and Cooling Silencer 750w : Samsung 22" 226BW 1680x1050 : Thermaltake ArmorPlus : WD 150GB Raptor : 2x Custom Watercooling Loops
Reply to hawkspur
actually theres a ddr2 version of the 8600gt that comes in 512mb - 1gb memory
Reply to wh3resmycar
It's gaming performance will suck more than usual?
anyway try GPU-Z
------------------------------ "As in what you hapless techno wienie?"
"It's stupid man, it's universally stupid"
"AHoo! BOOM!"
Reply to Blackra1n
There are 1288 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
