I just recently built a pc (Windows vista ultimate x86) with a Gigabyte GA-P35-DS3L. Everything works great except for the front panel audio. At first I was having problems trying to figure out how to get the front panel audio to work, but now I have a different problem. I read different forums in here that stated how I needed to disable front panel audio detection in order to get it to work. I did that and true enough, I could get audio from the front panel. The problem that exists now is that I am getting sound from both the front and the back even when I have headphones in the front panel. It does not mute the back (main speakers) even though i have the play back device option set to "Mute the rear output device, when a front headphone plugged in". I have tried setting different options to no avail.
Did you use the HD audio connector or the AC97 front panel audio connector?
The computer allows you to make mistakes faster than any other invention, with the possible exception of handguns and tequila- Mitch Ratcliffe
I used the connector that came with the case. Based on the case website (Raidmax), I believe it is an AC97 connector. Do I need to purchase a separate connector, and if so how would i replace the existing one?
Thanks.
I belive but am not positive that you must change some jumper if you are using AC97 Front panel audio connector, I look it up in depth possibly.
