Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Help with Liquid Cooling Brands
Forum Overclocking : Cooler and Heatsinks - Help with Liquid Cooling Brands
Needed some advice on Liquid cooling...
1. 1/2 tubing, 3/8 tubing or 1/4* tubing (which one would you recomend and why?) Also what brand of tubing would you recomend
2.Good brand of non conductive Coolant
3. how many L/G per hour on the pump
Thanks!
EDIT: sry ment to put 1/4 tubing
Message edited by swat565 on 09-15-2008 at 07:38:53 PM
Sponsored Links
1/2, 3/8 or 1/2? ........
UHM. anywho, get the biggest tubing i guess.. allows more coolant flow.
Reply to V3NOM
What do you plan to cool and do you plan to OC?
1. I personally prefer 7/16" ID MasterKleer. MasterKleer is not quite as flexible as Tygon, but is half the cost. About the same flow as 1/2" ID but givesa tighter fit over barbs. Takes up visibly less room than 1/2". I would avoid anything from local home supply stores. It'susually very stiff and hard to work with. I'm assuming the barbs are 1/2 "
2. Non-conductive fluid is a waste of money,IMO. It may be non-conductive out of the bottle, but will pick up particulates and ions while in the loop and thus become conductive. It's better to just plan for no leaks.
I personally like either Swiftech Hydrx, Pentosin plus PT Nuke, or Primochill Liquid Utopia - each mixed with DISTILLED water.
3. L/G per hour can be a misleading number (can be manipulated). Better to go by Head measured in feet or meters (the higher the better). That said, unless you have a lot of money, the real choice is between the MCP355 (DDC 3.2 with a Petra's or XSPC top) or the MCP655 (Laing D5). No need to look at any of the others. If you've got money, then the Iwaki RD-30 is probably the top pump.
Message edited by TonyL222 on 09-15-2008 at 05:13:29 PM
------------------------------ Intel Q6700 Quad/D-Tek Fuzion V1 with 2xPA120.3/ASUS Maximus II Formula/PCP&C
Silencer 750/Corsair Dominator 4Gb PC28500 memory/Corsair Dominator Fan
VisionTek Radeon HD 4870/Swiftech MCW60-R/Raptor 150GB HDD 1 X WD Caviar SE16 500GB HDD/Mountain Mods
Reply to TonyL222
Hydor makes pretty good pumps, as does Eheim.
------------------------------ The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Reply to rubix_1011
2. I agree with Tony on this one. It is a waste of $. Just use 50% ethelyne glycol and water(NOT regular tap water!).
3. Agree with Tony on this again.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Deleted by Moderator
Message quoted 1 times
Message edited by Jake_Barnes on 09-17-2008 at 04:29:12 AM
Reply to Conumdrum
Conumdrum wrote :
Why use antifreeze? It's well known in WC circles that Distilled water and biocide is all you need.
True. But the additives I listed are very cheap insurance- provide anti-corrosive, pump lube, and boicide. Besides - the UV glow is cool :)
Message edited by Jake_Barnes on 09-17-2008 at 04:32:15 AM
Reply to TonyL222
- 0 +
thank you Conumdrum, these forums have been hell to find out ANY thing about WC that actualy pertains to what i post on, and if it does they have NOTHING to prove what there saying is true (aka reviews or personal experience, its "just the best setup" )... So il be posting at the link, due to this post turning into a bickering contest..
Reply to swat565
Look, you can cheap it out and get as inexpensive materials as you can or you can spend what amounts to just a few dollars more for some piece of mind.
1) IF you want ideal tubing for a 1/2 ID cooling loop than do a little shopping for some 1/2 ID 11/16 OD Tygon tubing. I feel that the best place for it is here:
http://www.sidewindercomputers.com/tubing.html
2) Since you asked about non-conductive coolants - take a look at PC-ICE. It is a little pricey (around $19 for 32oz) but I have been using it exclusively for over 6 years in my various cooling loops (both straight liquid cooling AND peltier cooling) and it functions as advertised. I have had a leak or two and spilled it on active parts and nothing happened. Another benefit of PC-ICE is that it acts as a lubricant for your pump and has anti-biological properties to retard algae buildup. I wouldn't touch Fluid-XP as it has been known to create buildup.
Here's a review by Gruntville: http://gruntville.com/reviews/wc/vm_pcice/index.php
3) You are going to hear about GPH or LPH and you will also hear about head pressure but the fact of it is that if you aren't going to be a hard core water cooler (I mean watercooling, say, more than 3 components - HDDs, NB, Crossfire video, CPU, mosfets) and just want to cool, perhaps a CPU and a single GPU than I wouldn't concern myself with head pressure too much because the size of your cooling loop will never be in a situation where head pressure will matter. Rubix does make a point of mentioning the Hydor and Eheim pumps AND they are some powerful ones but they are AC. The Swiftech pumps are 12v and will use a plug off of your PSU. Creating a 1/2 ID cooling loop will give you more forgiveness with the additional bends and turn as you add to the loop in the future.
Prepping yourself for expansion would be wise and alot of what you will end up doing is going to be predicated on your O'clocking philosphy (as it develops).
For a 3/8 loop the ideal pump is going to be the MCP355 (if you go Swiftech) as it is a native 3/8 pump (although you can get a 1/2 fixture to change it). Be aware, though, if silence is also important - the MCP 355 is audible.
for a 1/2 ID loop the MCP655/D5 Laing (not the "B" version) is the most popular for s number of reason - good GPH, good head pressure and it is dead silent.
Just all food for thought.....
Message edited by phreejak on 09-16-2008 at 12:53:18 AM
------------------------------ Swiftech Mcres-Micro Reservoir, MCP655 Pump, D-tek Fuzion CPU Waterblock w/nozzle kit, Thermaltake Toughpower 1200, Swiftech Stealth GPU Waterblock, 2 external dual 120mm rads (each with four 120mm fans in "push-pull" )
Reply to phreejak
Bickering? Not sure who you feel was engaged in bickering. I think I was pretty clear about what was my opinion vs what is an absolute. Phreejak and I differ on some maters of opinion and that's all good. What that says to you is that you should study up on the subject, listen to what others with experience have to say, then make up your own mind. I absolutely encourage you to visit other sites and get oher opinions - but for the most part they are sill just opinions.
On the pumps - I feel confident that my recommendations will fit 99.999% of anything you want to do. By all means seek other opinions, though.
Tygon tubing is a great choice in tubing and very easy to work with for a noob. I've worked with it before and love it. MasterKleer gives you very good workability at a lower cost. That might not be important to you. personal choice.
From a performance standpoint,I don't think you'll be disappointed with either the MCP 3555 or 655. both are outstanding pumps. The 355 is smaller and more compact, and uses separate barbs. The 655 is larger, proven longivity, and fixed 1/2 OD barbs. For most loops, the LPH or head pressure differences between these two pumpa won't matter. IMO you'll get similar cooling performance with either.
IMO, paying $20+ for non-conductive coolant is not worth the money. Some will argue for and some against. I've given you my opinion and why - and clearly stated that it was my opinion.
I frequently quote the resulst of test from people like Martin of Martin's Liquid Labs. But I', sure even he would sya that "your actual milage may vary."
Message edited by Jake_Barnes on 09-17-2008 at 04:30:40 AM
Reply to TonyL222
There are 481 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
