I've searched a dozen different ways and read Newegg reviews til I'm blue in the face... I can't find enough reliable information on which card works best with Vista 64 home premium (I'm buying the retail Vista 32bit Home Premium and will be sending off for the 64bit).
I'm picking the parts for a new gaming system and the sound card is the last piece that I just can't decide on. No sooner than I have one picked out and in the cart, I find another set of horrible reviews, driver issues etc.
For those of you running Vista 64, which sound card have you had the best overall luck with? I'll be using a set of Creative 5.1 speakers and would like to keep surround sound.
I don't think it matters in relation to a sound card, but just in case, I'll be using an nForce 780i, 8GB ram, Q6600, 850w PSU.
Suggestions are appreciated. (excluding those recommending against Vista)
Cant say as i've researced sound cards etc, but my X-Fi Fatal1ty works fine on 64bit ultimate.
I'm pretty sure all the features etc work just as well as the XP drivers, if theres any features that arent supported (yet) ive not seen them.
P.s, personally i dont understand all the vista bashing, ive built 2 high-end systems based on Vista x64 Ultimate & its definitely my favorite Microsoft OS to date & when SP1 is released hopefully it will solve the only gripe i have with it (50fps insted of XP's 80fps in some games)
Message edited by Blank2k2 on 03-15-2008 at 03:16:35 PM
I've used the X-Fi fatal1ty as well as the SoundXtreme or whatever the cheapest one is. Both worked fine with Vista Prem 64. I have also used the Striker sound cards without issue. Out of curiosity, why are you buying retail? Buy the OEM 64bit for ~$120 at Newegg.com and save some money. You won't have to send away for the 64 bit version either, so you'll be able to use it right away.
Be aware that EAX support in old games is broken in Vista because DX10 doesn't handle sound anymore. If you have games more than a year or 2 ago and want EAX features, you need to install ALchemy. It converts DX based EAX effects into the new OpenAL. Check out Creative's site for it.
I'm buying retail mostly because I'm sure I'll have to reformat a few times and I've heard that M$ basically has the option of whether or not they want to let you do it. The other reason is that if I buy the 32bit retail, I can spend another $15 and get the 64bit too, so I'll have both. I'd like to have both just in case I do get some of the issues I've read about that are associated with 64bit.
If I'm just really really wasting money- please let me know!
Thanks for all the replies. I'll look at the cards you guys mentioned and try to decide. It may just come down to a coin flip or price check then lol.
Its recommended to use OEM.....You will save a lot of money. The added cost goes to the fancy microsoft box.
The OEM version costs less to buy, but if you have any problems, you have to pay M$ for support. The price is low because it assumes that the person using it knows how to install and fix the problems already. Also, if you get the OEM version, you can't change the motherboard or possibly the CPU itself. Doing so means that a new computer is created in Microsoft's terms of the ULA.
If a person absolutely knows that he is never going to change the motherboard or possibly even the CPU, and for sure he will not have to call M$ for support, then an OEM version if Vista is a good deal. Otherwise, the retail version is better, even though it costs more.
Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
If you are planning to use 8 GByte of RAM you have no choice but to go 64BIT OS. The 32 bit OS don't support above 4 Gbyte of memory.
Well, 64bit AND the 8GB ram are the two reasons I was thinking about the retail and getting both versions. That way if I run into a show-stopper with either the 64bit or the 8GB, I can always drop back to the 32. IDK- it sounded good when I read about doing it that way.
Its unlikely I would ever change out the mobo or HDD unless one of them just quit. Since I only upgrade about every 3-5 years or so, I'd probably start with all new parts like I am now. Do the OEM versions let you do unlimited reformats if you screw up your system and just need a fresh install?
That is questionable. From M$'s own ULA, reformating without changing the computer components should be possible. You just need to get M$ to authorize it, either on line or by phone. I've had the experience in the past where M$ said no, but then relented when I complained loud enough. And that's why I only buy retail now.
As for getting 64 bit and then dropping back to 32 bit, I don't think there would be any advantage. The only good reason for 32 bit Vista in the first place was so that people who wanted it have DX10 on a CPU that was only capable of 32 bit, they could. I don't know any good reason what so ever for someone with a 64 bit capable machine to use 32 bit Vista. It only would handicap you.
OH- I thought I had read that there were specific driver/emulation issues with 64 that 32 did not have in some cases. Specifically with some of the Creative sound cards..
I'll have this box (my curent one) with XP on it so I'm not horribly worried about not getting to use some software programs. I just figured that for $15 more it would be a nice back up plan.
I also opted for the home premium vs the Ultimate. I didn't see any real advantage for the Ultimate unless I am just missing it?
Creative put out new drivers for Vista, so no problem remains as far as the 64 bit version goes. And I do have a machine with 64 bit Vista and a Creative Fatal1ty Platinum card which works fine, so I write from personal experience.
The Ultimate version gives you a few advantages, combining the features of Premium and Business Editions, with a few multimedia features as well. If you don't need the features, there's no reason to spend the extra money on them.
I guess I'd rather avoid future issues all together and just get the retail. There's a good chance that it would go on my next box as well anyway. The next OS isnt due out until 09/10 so Vista will be around a while yet I'm sure.
I think I've decided on the Creative Sound Blaster X-Fi XtremeGamer http://www.newegg.com/Product/Prod [...] 6829102006 unless someone knows something horrible about it. It seems to be a fair compromise between price/performance.
I'm not a huge audiophile, but would like games to be crisp and clear. I'm also avoiding onboard sound due to running a 24" lcd at 19x12 on an 8800GTS. I figure as some of the newer games are released I'll need all the fps I can squeeze out.
You're right, the onboard sound cuts 2-5 FPS, and many of us are struggling to get all the FPS we can get. Some people will say that anything over 30 FPS is good enough. I personally like a minimum of 60 FPS, which is pointing me to getting a Crossfire setup.
From what I've read and estimated the setup I will be running should pump Crysis at high settings with about 33-37 FPS. I agree that I like to have a little over the 30 and do tend *feel* better about it closer to 60. I didn't really think about it that much until I stated using an RC flight sim. The FPS made a huge difference in reaction times...
Hopefully the Crossfire will work for you better than SLI did for me. I'm only running 1440x900 so I am more CPU bound that not, but untill SLI runs just like a single card I won't do it again. I really didn't notice any difference in any of the games I played even when I turned up the eye candy. Not enough current games I play support it and or the driver just runs it in single gpu mode anyway.
I had SLI once in the past and found it more of a hastle than anything else. It helped sometimes, but much of the time it didn't do any good. My present monitor has 1680 x 1050 adn I'm thinking of stepping up to a 24", so I need power to fill the screen. Besides, I plan on ordering a X48 and a Q9550 and that combo only takes Crossfire. I'll use a single card for the moment, but when the 4800s come out, I plan on getting two of them.
Here's the 24" I'm getting. It's not top of the line by any means but it has excellent reviews on newegg and elsewhere with a really nice price point.
