Have a problem with wave sound in master volume window
Hello all,
I use WMP 9 and gom player. when I use the gom player be m2ts/avi/ whatever and i use the mouse scroll wheel to decrease volume it comes down really hard and then double clicking the speaker icon in the tray shows the "wave" levels down. How can I configure it to only use the main volume to increase or decrease volume locking wave?
Evga 780i FTW
q6600
9800GTX
3GB ram 1066
thank you
1 answer Last reply
More about have problem wave sound master volume window
  1. single click the speaker icon, and that brings up the master volume.
    Or point at the place on the volume bar that you want to adjust the volume to, then single click. The volume control should go to the place that you are pointing.
Configuration Windows XP
