Which Power Supply?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Which Power Supply?
Profile: stranger
More Information
I'm building a new machine and need some advice on the power supply.
Heres what I'm going with.
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz Processor
EVGA GeForce 8800GT 512MB Video Card
Seagate Barracuda 7200.11 500GB SATA Harddrive
CORSAIR 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
For the case  I'm thinking  the Antec 900
So, what requirements am I going to need from my power supply?  Who makes a quality power supply?
500, 600 watts?   And I would like it to be relatively quiet.
Related Pr oduct
Do not eat the styrofoam
Profile: Forum Veteran
More Information
Corsair 620HX, Silencer 610W
Upgrade to 8800GTS 512MB if you can.
werd.
Profile: addict
More Information
I am getting a similar system and will be using a Corsair VX550. Trust me, it will be plenty. Don't listen to people who tell you you need like 700 watts. Get a quality 550 one. You could probably run that entire system easily on a good 450 watt power supply, but it wouldn't be as good for upgrades. Here is the PSU that I'm getting for my rig (in sig) http://www.buy.com/prod/corsair-vx [...] 52646.html It will be enough for more hds and RAM most definately, and I suggest you buy the same one. If you want to get something else, then go here: http://www.xtremesystems.org/forum [...] p?t=108088 It has all the high quality PSUs in teirs. Though it's not exactly up to date, it gives you a good idea of what PSU brands suck and which ones don't.
"Steve Jobs is not making enough money"
E8400|4GB|HD4870
If life is just a joke then y are we laffing
Profile: journeyman
More Information
i have the   OCZ GameXStream 600w Silent SLI Ready ATX2 Power Supply http://www.overclockers.co.uk/show [...] ubcat=1098 and it is grate chek my system in my sig. it is verry  quiert
BAM!
Profile: Faithful Poster
More Information
im with doomsdaydave... a good 500-600 w will be more than enough
Corsair 550
Corsair 520
AntecTrio
"The MB is 31 C and the CPU is 109 C.  I think it's the CPU overheating." - Faromic THF's
Profile: journeyman
More Information
I am running a similar system
9600GT KO
and E4600
w/ a Corsair VX550W it is rock solid i love this PSU.
More Information
since you sill not be adding a second card you do not need a 750
a 600-650
antec triple 650
silverstone strider 600 or zeus 650
pc power cooling 610
all these have 38-42 amps on the 12v run cool and run at 80% or higher will your set up.
with the antec 900 move the bays up 1 slot you cool the ram better!
custom light switch can be made is 10 mins:
http://i63.photobucket.com/albums/h138/4rothrocks/DSC_0110-2.jpg
http://i63.photobucket.com/albums/h138/4rothrocks/DSC_0113-2.jpg
lights are mounted on top both - 9 led uv 12"
cut a hole 1 inch ssquare to run the 12v 8pin to top
cut a hole 1 x 2.5 inches for the power cords out the bottom
if you have the new 900 you have 2 holes precut on the side - old one does not so cut - if you do not cut 1 x 2 hole to run the 24pin atx cord
http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Profile: old hand
More Information
Here's an Antec P182 case $70 after MIR;
http://www.microcenter.com/single_ [...] id=0257446
Or the 900 for $80
http://www.newegg.com/Product/Prod [...] 6811129021
Opinions are like asses,everybody has one.
Add a reply
Google Ads
