On the PSU site it says the 8 pin connectors are downward compatible but what does that mean? The 8 pins won't fit over the 6pins of the gtx looking at the pic's. There seems too much plastic in the way on the side to fit the 8pin with 2 pins unused.
Any idea's what to do or should I just get another PSU with 6x6pins?
I tought one with the 8pins option would be more futureproof?
It indeed has 3 of each king (6pin and 8pin) but that means I can only run one card like the 9800GTX having two 6pin :-(
Unless I can find a way to convert the 8pin's to 6 pins.
