Tom's Hardware > Forum > Smartphones & PDAs > Palmtops > Clie losing all data after battery discharging
Forum Smartphones & PDAs : Palmtops - Clie losing all data after battery discharging
Archived from groups: comp.sys.palmtops (More info?)
I have a Sony Clie SJ-22 and a while ago I went on vacation and left
it at home. When I came back it would not turn on. So I recharged it
and it turned on, but all the data disappeared. It was back to like
if I had just bought it new from the store--gave me the prompts to
calibrate the screen, had to set the date, etc, and reload all my
software and data again.
Recently, the battery discharged again after I let it go weeks without
recharging. The same thing happen. To test it, I let it discharge
one more time on purpose this time. All data gone again.
This is not how my Palm(tm) PDAs behaved. I had a IIIe, IIIxe, IIIc,
and a Vx, and all of them would not lose the data even if I let it go
without charging for months. In fact on the III series, I could
remove the batteries and the data would still be safe.
It this a Clie "feature", or do I have a bad unit?
Thanks.
Sponsored Links
I have a CLIE PEG-N770 and it does the same - but at the end of the day,
that's why you synchronise with your PC it is it not?
"PLEASE NOTE : Care Should Be Taken When Lifting This Product, Since Its
Mass, and Thus Its Weight, Is Dependent on Its Velocity Relative to the
User."
"Marcio Watanabe" <Marcio@nospam.com> wrote in message
news:podlb0t0u30brj9g8iik1t4nq9nsa03p4g@4ax.com...
> Thanks.
Reply to Anonymous
Hi Marcio,
my wife has the same problems with her SJ-22.
She uses it until the "Battery low" alert is displayed.
Now she has about 1-2 days for charging. After this period all data are lost. :-(
I assume, the voltage level for the battery low warning is too low.
I would appreciate it, if somebody could provide us with a tool, which displays
the warning message at a higher voltage level.
Didn't have a look at sony's website.
Does anybody know, if there is some system update available?
TIA
Olaf
Reply to Anonymous
- 0 +
That's how all handheld devices work. Power is needed to keep the data in
RAM. Your old Palm device may have had a backup battery that let you safely
remove the battery for a few seconds. Also, your old devices probably used
store-bought AAA batteries that lasted longer than the Li-ion battery in the
Clie.
P.S. Sony just announced they're no longer going to be selling PDA's in
America.
> Thanks.
Reply to Mike
>Clie.
The IIIc and Vx are rechargeables. I have let the IIIc discharge
until it would no longer turn on several times and it still kept the
data.
Reply to Anonymous
> data.
In my opinion there is one important difference:
I assume, the Vx stops working on a higher battery level. That means, it has
enough power to keep the data for many weeks.
The sony warns you about an empty battery just before it's really empty - and
all data are lost.
Those are assumptions, but I'm nearly sure, that setting the battery warning
level to a higher voltage would help.
I'm afraid, that this warning level is part of the ROM.
So you would have to flash an update from sony - if available.
Or you could install a tool, which is able to set the warning level in RAM -
means, that you have to set it up every time after a hard reset manually.
Olaf
Reply to Anonymous
There are 566 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
