I run my cable internet through the router named above. When I set my router up, my phone functions perfectly but I only have limited internet connectivity. I have cycled the router and modem many times, but to no avail. Here are my ipconfig settings:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\USER>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : USER-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8168/8111 Family PCI-E Gigabit
Ethernet NIC (NDIS 6.0)
Physical Address. . . . . . . . . : 00-1D-7D-A9-07-AA
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IPv4 Address. . : 169.254.150.122(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 0.0.0.0
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 9:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : 6TO4 Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Unsure what to do about my default gateway coming up as 0.0.0.0. I have tried to access my router settings through 192.168.0.1 but the connection timed out. I have also tried disabling IPv6 but that didn't work out either. Any help would be appreciated. Thanks!
When I go straight from my modem to my computer, I experience no interent connectivity issues at all.
Sponsored Links
The address found in RealTek adapter section, 169.254.150.122, is the default address if Windows cannot find an IP address. It means your Windows didn't get an IP address from the router. Try ipconfig /release and ipconfig /renew.
You have IP phone? I don't know about subscriber services like Vonage but Voice Over IP takes a lot of (upload) bandwidth. Check here: http://ezinearticles.com/?How-Much [...] ?&id=57850
Reply to JustAGuy51
Tom's Hardware > Forum > General Networking > Network General Discussions > D-Link VWR-VR Issues
There are 1171 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
