Tom's Hardware > Forum > Storage > Optical Media > Help! lg sata burner detected but won't read!
Forum Storage : Optical Media - Help! lg sata burner detected but won't read!
Hi, today I boought the lg gh22ns30, connected it and everything seemed fine, detected in bios,windows,...but it won't read anything. I have the abit ip35-e mobo and theres just one sata hdd connected, tried with different ports,new chipset drivers but nothing helped
Sponsored Links
It sounds like either a bad disc or drive.
Try different discs in the drive....and try the same discs in another drive. That will give you your answer.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
- 0 +
thx for the reply, I tried different types of discs, I'm just to be sure it's a bad drive before the replacement
Reply to nexion
- 0 +
Does the drive show up under My Computer?
Reply to aford10
- 0 +
Yes, it showed up bu it's ok now, I replaced it, can't believe their selling defect hardware. Thx for the replies
Reply to nexion
- 0 +
DOA's happen.
Reply to aford10
There are 484 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
