Tom's Hardware > Forum > Homebuilt Systems > New System Build > Having problems with new build plz help!!!
Forum Homebuilt Systems : New System Build - Having problems with new build plz help!!!
OK so I just hit the power button on my new build to find the CPU fan is not spinning.. Everything else works fine. I did notice when I hit the power button 2 times once in a while the cpu fan will start up.
Any idea plz!
I have a Freezer 7 pro with a e8400
GIGABYTE GA-P35-DS3L LGA 775
Case 900
Sponsored Links
DS3L is notorious for doing that: cpu fan not spinning up at cold boot, but spinning up after a while. The cpu is cool enough. That's why.
Reply to akhilles
I believe its called SpeedStep technology. Basically, your fan only spins when the CPU gets to a certain temperature. My DS3L does that as well. It's nothing to worry about. You can disable it in the BIOS if it bothers you.
------------------------------ PSU: Antec Earthwatts 500 watts
Mobo: Gigabyte P35-DS3L
CPU: Intel Wolfdale E8400 @ 3.4GHz
Video: Evga 8800GT 512MB
Reply to nforce256
that does seem wierd... but then booting then turning off, then booting again is a bit wierd as well... (my MSI does that)
Reply to amd_fanboi
There are 514 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
