Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > can micro atx power supply power on 8800gt, 9600gt, or ati 3850.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - can micro atx power supply power on 8800gt, 9600gt, or ati 3850.
Well, im building my own pc case to replace my old outdated xbox 360. My goal is to make a gaming pc with a case as small as xbox 1. Will a micro atx powerful enough to power on 8800gt, 9600gt, or ati 3850? If this 2 power supplys below cant handle it, what power supply is recommended? it needs to be small as possible. Current spec are:
Asus m2a-vm
Patriot 2gb 6400 Lat:4
AMD 4200 x2
xp pro
hdtv 720p
no graphic card yet
power supplys will they work?
LOGISYS Computer PS350MA MicroATX 350W Power Supply 220V FCC.UL.CUL.CE & CB - Retai
http://www.newegg.com/Product/Prod [...] 6817170015
SP Group FSP300-60GLS-MJR MicroATX 300W Power Supply UL, CSA, VDE, NEMKO, TUV, CE, CB, FCC - Retail
http://www.newegg.com/Product/Prod [...] 6817104044
or is there any very small atx power supplys.
http://i191.photobucket.com/albums/z19/Mohikan2004/atari2.jpg
http://i191.photobucket.com/albums/z19/Mohikan2004/atari23-1.jpg
Message quoted 1 times
Message edited by rickpcnerd on 03-19-2008 at 01:10:29 PM
Sponsored Links
350w is too low for those, its cutting it close, and brand name DOES say more than anything in the specifications. Also you will need PCIE connectors, which neither PSU have. Get this power supply and stop being cheap, people who are cheap with power supplies don't have working computers for long, sorry. Hope this helps, I am using the 750w version and its an amazing peice of hardware, get it, you can run it outside the case. Otherwise I will update this when, or if, i find a decent micro ATX PSU
http://www.newegg.com/Product/Prod [...] 6817703011
Also, I like that case but the picture on the side with the guy and the sword looks kind of overdone, just my opinion.
Message edited by The_Blood_Raven on 03-20-2008 at 02:30:47 AM
Reply to The_Blood_Raven
Yes, they are call MicroATX.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
You need at least 380W with 18A on the +12 rail. Looks like you are out of luck for a good PSU to power those cards.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
- 0 +
well................................ the 8600GT gets all of its power from the PCIe but it is not a gaming card.
im not sure about the 9600GT with passive cooling
edit: oh yeah you are bogged down, no PCIe connectors?
http://www.hardwarezone.com/news/v [...] 0033&cid=6 -from what i can see it still needs a 6-pin connector
Message edited by sabot00 on 05-04-2008 at 05:50:14 AM
Reply to sabot00
You'll need a PS with 30A or more available on +12V in order to run a power-hog graphics card like an 8800GT.
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
- 0 +
you can use a MicroATX PSU & add him a VGA PSU, TT has one with 250W of 12v= 21A just for the VGA.
------------------------------ you don't want to know...
crysis DX10 1280x800 at 35-40FSP is the Target.
Dell 27" 1920x1200 is huge!
Reply to z_dori
There are 1412 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
