Tom's Hardware > Forum > Homebuilt Systems > New System Build > Quick question, problem during build
Hello,
First time putting a build together. I got a Biostar TA770 board with a Thermaltake 500W Purepower PSU. Now my question is the pin connector on the MOBO is a 8pin for the +12V. However, the PSU has a 4-pin +12V connector.
Can I plug that 4 pin in the 8 pin? Will it work? Or do I need to get a new PSU?
Thanks.
Sponsored Links
Quote :
The 4 pin should work just fine.
Reply to rgeist554
- 0 +
If it dosn't work, pick up one of these: http://www.newegg.com/Product/Prod [...] 6812201005
Check at RadioShack, or a local mom & pop shop
Reply to IH8U
bbfifas wrote :
Hello,
Thanks.
It should work fine, most motherboards will. If it doesn't boot or it keeps freezing/rebooting while running, this might be the problem. If you plan on overclocking, get the 4pin to 8pin adapter because your motherboard will need the extra juice. :) Plan on putting it together and getting it running and order the part, when it comes in, take 30 seconds to add the adapter just to be safe. :)
Reply to gwolfman
- 0 +
Thanks for input so far. I will try it as is. Just kicking myself for not getting a 8 pin PSU...dumb me.
Reply to bbfifas
There are 998 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
