Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Monitor displays blank screen and sometimes Check Signal Cable error
Forum Graphic & Displays : Graphics Cards - Monitor displays blank screen and sometimes Check Signal Cable error
Problem: Monitor goes blank and blinks between "Analog" and "Digital" at times, and sits at "Check Signal" other times.
Windows XP Home SP2
Samsung 931B using DVI @ 1280x1024
EVGA 7900GS KO
Gigabyte GA-965P-S3
C2D E4300
Enermax Liberty 500w
Monitor will go blank at random times (not just at boot up). It seems to be checking for a signal. If this happens while my PC is up, it will freeze the PC. However, if the monitor goes blank during or before boot up, my PC will actually boot up and not freeze while the the screen remains blank.
When the screen goes blank while my PC is up, the fan on my 7900gs accelerates and does not stop. However, the card is just warm, not hot. The card gets MUCH hotter during COD4 and HL2EP2.
Once blank, the screen does not return back to normal without rebooting. Even then, it usually stays blank.
This just started happening a month ago, and was intermittent. However saturday (I just started playing HL2 Episode 2) it became chronic.
Nothing has ever been overclocked. And it hasn't happened yet while in safe mode.
Checks performed:
-Power monitor and PC off and on
-Tried the 2nd DVI port on the 7900GS
-Tried VGA cable instead of DVI in both graphics card ports
-Uninstalled and reinstalled graphic driver
-Uninstalled and reinstalled monitor driver (both digital and analog)
-Reseated graphics card
-Tried different resolutions
-Samsung monitor check succeeds. The "Check Signal" shows accurate colors
-Holding the "Menu" button while screen is blank says it's fine
-Pressing the "Source <-" button on the monitor does not correct the problem
-Made sure all other drivers are up to date
-AVG, Spy-Bot and Ad-Aware did not find anything
-It's not the monitor. I swapped my wifes CRT and the problem still happens on her CRT.
any help or ideas are appreciated
thanks
Sponsored Links
I have fixed PC's in the past with this problem. Generally, its related to the motherboard not detecting the graphics card. So, You need to get a cheap graphics card. You didn't say if you have an AGP or PC-express slot. If you still get the `Check Signal error` then the motherboard is fried. I`m actually fixing a PC right now with this very same problem! Waiting for 2nd graphics card to test! lol
Reply to scotsfilmmaker
I had this about a month ago. I fixed it by removing the card and giving everything a good spray with a can of Dust off, followed by a spray of contact cleaner. I live in a humid country and I think the card gets oxidation. Hope this works for you.
Alison
Reply to Alison_88
There are 789 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
