First my rig:
MSI K9A2 Platinum
AMD 5000+ BE
4X G.SKILL 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
EVGA GeForce 8800GT
Asus lightscribe 20x dvd-rw SATA
Antec Earthwatts 500W PSU
4 120mm fans
2 Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA-300 Hard Drive
Artic cooling freezer 64 pro
Now the problem:
Installed new hardware no problem. Trying to do a New install of XP, works fine untill it gets to the "setup is starting windows" blue screen where it just hangs there. I disabled all the usb and Ieee devices, reset the bios and cmos, tried install with just 1GB and 2GB no luck. Tried to install with one SATA HDD and IDE DVD_ROM with no luck. I forced memory timing to rec setting of 5-5-5-15 with v1.9 fq. I have IDE set instead of RAID and AHCI. All power cables are plugged in. Preformed memory test using windows memory diagnostics tool found no problems at 5 passes when run on both medium and high setting. RAID is off and both HDD are brand new. tried switching sata ports still same issue. For vista the same applies, slapped it into the drive to install, the "windows is loading files" screen finishes the bar at the bottom then all i get is a black screen. Ive tried all the steps above with vista and still the same results.
MSI K9A2 Platinum
AMD 5000+ BE
EVGA GeForce 8800GT
4 120mm fans
Now the problem:
