Correct Registry Setting for Conexant 221 Audio
Does anyone here have Vista 32 Conexant Smart Audio 221 Correct Registry readings for the Audio Device? Mine all seem to have a0000000 value and I thought if I can restore the correct settings I might just get my sound back! Two weeks w/o sound!
H KEY LOCAL MACHINE
SYSTEM
CURRENT CONTROL SET
CONTROL
CONEXANT
SOUND SOURCE
then
AUDIO CONFIG ( audio config is the area I need the settings for)
any help is greatly appreciated!
Thanks.
2 answers Last reply
More about correct registry setting conexant audio
    H KEY LOCAL MACHINE
    SYSTEM
    CURRENT CONTROL SET
    CONTROL
    CONEXANT
    SOUND SOURCE
    then
    Thanks.
    Why not just uninstall the driver, and reinstall ?
    http://download.cnet.com/Conexant-High-Definition-SmartAudio-221/3000-2110_4-177475.html
  2. The drivers will not install, because there is NO Audio device detected. I have been through all of that (and more)already, but thanks for the reply.
Configuration Audio Registry Conexant Windows Vista
