Tom's Hardware Forums » Motherboards & Memory » Aopen » Motherboard Problem! Help!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Motherboard Problem! Help!
Profile: stranger
More Information
I have an old AOpen AK86-L motherboard with an Athlon 3200+ and I replaced the HSF with a Coolermaster today.
The problem is now when I go to boot up, the standby light comes on.  The new CPU fan and GPU fan kick in, and it sounds like it's trying to boot up (there's no beeps and it doesn't turn itself off).
Any ideas?  Have I inadvertently knackered something?  Incidentally the motherboard battery (CR2032) ran out a while back.  Do I need to replace it in order to clear the CMOS?
Any help appreciated!   :cry:
Related Pr oduct
Profile: enthusiast
More Information
something is loose, recheck what you missed.
Profile: addict
More Information
Check and reseat all power cables to the motherboard and graphics card.
      Mike.
BAM!
Profile: Faithful Poster
More Information
You probably havent seated the Heatsink correctly, did you use thermal paste at all? i know alot of those XP's didnt like even starting up if they didnt have good contact.
"The MB is 31 C and the CPU is 109 C.  I think it's the CPU overheating." - Faromic THF's
Profile: stranger
More Information
I think I've killed something.  I reseated everything, and got a strong burning smell when I tried to turn it on again.  It seemed to be coming from the motherboard near the processor.  When I took the CPU out it didn't smell so I would assume it wasn't that?
Add a reply
Google Ads
