Driver is properly installed and i'm sure the speakers are working properly. Settings on Bios has been turned-on. However, i dont hear any sound coming our of my speaker system.
Somebody says i should put a jumper on the audio section of the board. My propblem is, i can't locate where to put that jumper.
Disconnect the front panel audio cable and try again.
Check the Master Volume for mute or low setting.
Please specify what kind of motherboard you have.
Older motherboards came with 2 jumpers on the internal audio connector, which should be left there, if not using the cable.
------------------------------Google is your friend and Bob's your uncle
Reply to evongugg
my motherboard is an ECS nForce3-A socket-754. The front audio panel wires are disconneted from the board. I've checked volume setings, mute, etc., all are in place and yet no audio is coming out. Im trying to locate the portion where to put that jumper but i cant locate it on my board.
