Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Config - Routing Problem - New to Cisco Pix
Forum General Networking : General Gateways, Routers and Firewalls - Config - Routing Problem - New to Cisco Pix
I am brand new to PIX and any Cisco products - purchased this 501 last week for the purpose of providing IP telephony for work-at-home users. Put in about 40 hrs in 3 days and have SIP Soft Phone working over this VPN. RD, ssh, ftp all work from off site to internal network over the VPN.
PROBLEM:
Once connected to the VPN client cannot access the Internet, only internal resources. Ideal solution would be client access to internal resources via VPN, and access to Internet via their cable/DSL connection so other traffic does not use VPN bandwidth.
Any help is greatly appreciated. Getting the SIP Phone working was a real chore and I am reluctant to thrash around at this point with my very limited knowledge of this product. Using VPN Client 5.0.4.
My email: lelyea@yahoo.com
My config:
Building configuration...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password .63TFKBPrxSpUCv5 encrypted
passwd .63pUCv5 encrypted
hostname cp
domain-name domain.com
fixup protocol ctiqbe 2748
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol icmp error
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip any 10.10.20.0 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 10.10.20.0 255.255.255.224
access-list inbound permit tcp any any
access-list inbound permit udp any any
access-list inbound permit icmp any any
pager lines 24
logging on
logging timestamp
logging trap debugging
logging host inside 192.168.192.4
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 188.208.182.5 255.255.255.0
ip address inside 192.168.192.51 255.255.248.0
ip audit info action alarm
ip audit attack action alarm
ip local pool GRP_01 10.10.20.10-10.10.20.19 mask 255.255.255.0
pdm location 192.168.192.4 255.255.255.255 inside
pdm location 10.10.10.48 255.255.255.240 outside
pdm location 192.168.192.175 255.255.255.255 inside
pdm location 10.10.20.0 255.255.255.224 outside
pdm logging errors 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 192.168.192.0 255.255.248.0 0 0
conduit permit icmp any any
conduit permit udp any any
conduit permit tcp any any
route outside 0.0.0.0 0.0.0.0 188.208.182.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:03:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.192.0 255.255.248.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 192.168.192.4 pix
floodguard enable
fragment timeout 10
sysopt connection timewait
sysopt connection permit-ipsec
sysopt connection permit-pptp
sysopt connection permit-l2tp
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup PIX_01 address-pool GRP_01
vpngroup PIX_01 dns-server 192.168.193.25 192.168.193.8
vpngroup PIX_01 default-domain domain.com
vpngroup PIX_01 idle-time 1800
vpngroup PIX_01 password ********
telnet 192.168.192.0 255.255.248.0 inside
telnet timeout 35
ssh timeout 5
console timeout 0
dhcpd dns 192.168.193.25 192.168.193.8
dhcpd domain domain.com
dhcpd auto_config outside
dhcprelay server 192.168.193.25 inside
dhcprelay server 192.168.193.8 inside
dhcprelay enable outside
terminal width 80
Cryptochecksum:6d85a4dbef6b655992
: end
[OK]
Sponsored Links
Resolved with split-tunnel.
Reply to lelyea
There are 995 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
