News
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Microsoft fixes critical IE problems
Published on December 14, 2005
Microsoft this week fixed a widely reported flaw in its Internet Explorer browser that had been used by attackers over the past few weeks to take over the PCs of unsuspecting users. Read more
E-voting worries focus on failures, not fraud
Published on November 10, 2006
Major electronic voting machine problems occurred in at least six U.S. states during the country's midterm elections, underscoring that system failure, not fraud, is the biggest issue facing future races, voting-rights activists and technologists said this week. Read more
Microsoft patches 20 security holes in February update
Published on February 14, 2007
Microsoft's monthly security update for February has gone live. Though it marks the first update since the consumer release of Windows Vista, none of the 20 fixes are for the new operating system. Read more
Latest Reviews & Articles
Best Graphics Cards For The Money: Jan. '09
Published on January 07, 2009
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Scorpio Blue: Big Notebook HDDs Go Mainstream
Published on January 06, 2009
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
Value In SLI? GTX 260 Core 216 Vs. GTX 280
Published on January 05, 2009
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
  Tom's Hardware Forums » Overclocking » CPUs » OC problems
OC problems
Word :   Username :
Bottom
Author
 Thread : OC problems
Profile: journeyman
More Information
Hello guys, i have couple of questions.. Ive tried to OC my CPU today but obviously it didnt go well.
what exactly i did:
vcore 1.3500v
mem voltage 2.085v
nb core 1.393v
vcore offset [off]
fsb - memory ratio 1;1
memory timing ; trcd 5 trp 5 tcl 5 tras 22
and after those changes i couldnt load up my system so ive tried to increase vcore to 1.4 but it didnt go well..
so basically tried oc to 375,400,425 but no work with extra volts apply and i changed my multiplier to 6x
pc specs;
intel dual core E6750
pn5-e sli
Message edited by s1ckz on 09-30-2008 at 12:39:46 AM
Related Product
Sniper
Profile: Forum Resident
More Information
So were you running at 6*375 or 8*375?
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
Profile: enthusiast
More Information
What speed did you set the cpu to? Did you read the OCing sticky, it should explain everything?
Profile: journeyman
More Information
multiplier is 7x
Message quoted 1 times
Message edited by s1ckz on 09-30-2008 at 01:14:30 AM
You tell me what I do.
Profile: Eternal Poster
More Information
but you tried 6x with 375,400,425
Sniper
More Information
Profile: journeyman
More Information
Are you sure??? Acording to Intel it's 8x.
See:
http://processorfinder.intel.com/d [...] Spec=SLA9V
maybe i screwed something so should i change to 8x and try OC again?
Sniper
More Information
Profile: journeyman
More Information
so what exactly i did wrong , and what exactly i gotta change? <3
Sniper
More Information
Set multi at 8x
SetRAM to FSB to 1:1
Set FSB to 375
Then do the regular Burn in/stability stuff and see. Please list your VID (Use CoreTemp/RealTemp for this).
Google Ads
