Hi
I've found the forums here and various other places on the net have been invaluable in me learning more about the different components in a computer and I've managed to put together a list of things I think I'd like to use to build a machine that will run my 3D modelling and rendering applications such as Cinema4D with ease.
I've never built a computer before though I've had a hand in upgrading my current one several times so I have a basic gist of how to go about it. I'd really appreciate if someone with experience in these things would run their eye over my list of components and let me know if I've made any glaring errors in choice or left anything vital out?
Case: Antec P182 Advanced Super Midi Tower
http://www.aria.co.uk/Products/Comp...anced+Super+Midi+Tower+Black+?productId=28846
Motherboard: Abit motherboard IP35-E Intel P35 LGA775 Core2 Quad / Core2 Duo / Core2 Extreme PCI-E x16 SATA 3G Gigabit LAN ATX
http://www.microdirect.co.uk/(17581)Abit-motherboard-IP35E-Intel-P35-LGA775-Core2.aspx
PSU: Antec NeoHE 550W Modular ATX2.0 + EPS12V PSU 80mm low speed/noise fan
http://www.microdirect.co.uk/productInfo.aspx?ProductID=11448
CPU: Intel Core 2 Quad - Q6600 - 95W G0 stepping - OEM
http://www.aria.co.uk/Products/Comp...600++-+95W+G0+stepping+-+OEM+?productId=28805
CPU cooler: Cooler Master Hyper TX2 CPU Cooler
http://www.aria.co.uk/Products/Comp...+Master+Hyper+TX2+CPU+Cooler+?productId=29655
GPU: XpertVision GeForce 8600 GT 512MB DDR2, PCI-E
http://www.microdirect.co.uk/(27100)XpertVision-GeForce-8600-GT-512MB-DDR2-PCIE.aspx
Hard Drives: Two (one for backup) Seagate 500GB Barracuda SATA II 300 7200rpm 8MB cache
http://www.microdirect.co.uk/(17045)Seagate-500GB-Barracuda-SATA-II-300-7200rpm.aspx
DVD writer: LG DVD ROM GDR-H30NBL
http://www.microdirect.co.uk/(21295)LG-DVD-ROM-GDRH30NBL-Black-16x52-IDE-oem.aspx
OS: Microsoft Windows XP Professional 64bit OEM
http://www.aria.co.uk/Products/Soft...ows+XP+Professional+64bit+OEM?productId=17981
I've been told that if I want to install XP pro 64bit on this system I'll need to install the drivers for the hard drives from a floppy disk so rather than buy one for this purpose I was thinking I might take the drive off my current computer just for that purpose (should it really prove necessary).
Thanks in advance.
Thanks in advance.
