Hi,
I bought a Zalman reserator XT, and have a problem that whenever i start the computer, the reserator starts(auto mode) and stops after less then 10 seconds, beeping and flashing, and even if i reset it, it always stops again and again.
If i manage to switch to manual mode, then if the volume is too low, it will also stop, but only if i set it to almost the highest speed, it works and stays running. The flow rate never exceeds 0.5.
I already replaced a reserator because of the same problem, and the replacement one has the same issue.
I am sure i degassed the loop properly, exactly as written in the manual, including tilting etc.
Is it possible that the shop had a bad line of reserators?
Please someone give an advice before i give up and return it to the shop. I am really frustrated because of it.
Thanks,
Yaron
Thanks,
Yaron
