Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > HD3870X2 & HDMI 5.1 Audio? Help!
Forum Graphic & Displays : Graphics Cards - HD3870X2 & HDMI 5.1 Audio? Help!
Ok, so I did what little ATI told me to. I installed the Realtek drivers, and went to Sounds in Vista, set the HDMI out as default audio, but it only has mono sound for Windows, no sound for all other games, Itunes etc. EXCEPT, all Source games (HL2) are perfectly fine when set to 5.1 sound. Any ideas on how to get this to work right?
Useful Info:
3870X2 with Catalyst 8.3
Vista Home Premium 32bit
Denon AVR-3808CI Reciever (connected via HDMI to 3870X2)
Onboard "HD Audio"
------------------------------ AMD Phenom 9550 OC'ed to 2.5ghz Sapphire HD3870X2 @ Stock (for now)
3GB Corsair XMS2 DDR-800 ToughPower 700watt Power Supply
ASUS M3A-32 790FX Wi/Fi Samsung 50" 1080p LCD TV
Sponsored Links
i have battling hdmi output on one of my machines - worked on it for several hours still no out put
mine shows as the realtech hdmi and shows up in the sound section of vista
but no sound, i tired enabling in different order still no sound out
try this:
http://www.tomshardware.com/forum/ [...] audio-3870
------------------------------ http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Reply to dragonsprayer
try this:
Thank you dragonsprayer linking to that thread helped me sort my problem. So I thought it was only fair after googling for hours I would sign up and say thanks to you and the poster of the link you suggested ;)
Reply to Nogimics
At least you're getting some output. I have the Sapphire HD 3870 X2 with HDMI output, and I don't get video or sound through the HDMI, but I can get video through DVI to HDMI adapters. I have tried force detect with CCC, as well as using Vista's display control. Nothing gives me video. I'm running an AMD Phenom 9850 with 4GB of RAM and the aforementioned HD 3870 X2. Any ideas would be appreciated.
Reply to neoknight88
There are 953 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
