Hola.
After fighting tooth and nail with my new HD4870 cards in CF, finally got all the problems sorted out and everything is stable, so i'm going to start overlocking my E8500. Here is my current system:
Intel C2D E8500 Wolfdale (3.16GHz) with Noctua NH-U12P cooler (cores sitting at about 44C idle and this seems a little high so I might lap the HS and possibly the CPU)
Asus Rampage Formula Mobo (BIOS 0410)
8GB Mushkin XP2-8500 Ram (4x2GB)
2x Sapphire Radeon HD4870 in Crossfire (card BIOS's flashed to latest Sapphire BIOS)
SupremeFX II "onboard" soundcard
2x 150GB WD Raptor HDs (RAID 0)
500GB WD Caviar HD
Pioneer DVR-115D
PC Power and Cooling Silencer 750 Quad PSU (5V@30A/12V@60A/3.3V@24A/750W Cont/825W Peak)
Antec 1200 Case with 3*120MM intake/1*120MM side intake/2*120MM rear exhaust/1*200MM top exhaust)
From everything i've read on various forums and tech sites, this PSU should be just fine running my system. But once I start pushing my CPU (not to the limit, just want to hit 4GHz or a little above) and OC my GPUs a bit, would this PSU start to be the weak point? How much extra draw will overlocking put on my system, assuming the OC is to a point where the voltage increase isn't drastic? Local PC shop has alot of PSUs in stock that I can go for if need be (Thermaltake, Corsair, FSP, Silverstone, Antec).
Thanks for any advice.
500GB WD Caviar HD
Pioneer DVR-115D
