Tom's Hardware > Forum > Motherboards & Memory > Memory > Incorrect memory speed being read
Forum Motherboards & Memory : Memory - Incorrect memory speed being read
Hey guys, I recently purchased a new machine and put it together myself, had a couple of teething problems (mostly software related) but I have it all running fine now. I recently ran CPU-z just for kicks and its reading my memory speed at 400mhz which I thought cant be right since its PC6400, 4GB (2x2GB) Corsair DDR2 6400 2x240 DIMM unbuffered 5-5-5-18 64bit OS DHX to be exact.
I checked my BIOS settings and all the timings are set to auto, when I changed that to manual all the timings seems to be set correctly. I would have left it on auto but thought I'd ask you guys for advise before I did anything silly.
Heres the CPUz screenshot of what it reads-
http://i199.photobucket.com/albums/aa91/FinchRGG/cpuz.jpg
Heres my specs if it helps at all
Windows XP 32-bit home (I realise I'm loosing out on 1gb of ram)
MSi P7N Platinum motherboard
Intel Core 2 Quad Q9300, 2.5 GHz, 1333MHz
Thanks in advance people.
Sponsored Links
It's called double data rate and it runs at half the speed you would think it does so 800 / 2 = 400 MHz. This is perfectly normal.
Reply to morga
It is fine. DDR2 is 400x2=800. Dual Data rate. Intel CPUs are Quad pumped.
No worrys. Good job.
Reply to roadrunner197069
^^^^agreed...
DDR2-800 runs at 400Mhz (400x2)
DDR2-667 runs at 333Mhz (333x2)
DDR2-533 runs at 266Mhz (266x2)
etc.etc
------------------------------ If fate really does exist, she hates my guys....
Reply to pinaplex
WRU sticky?
------------------------------ "He is no fool who gives what he cannot keep to gain what he cannot lose" -- Jim Elliott
Reply to leo2kp
There are 1203 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
