Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > INNOVATEK GEFORCE 9800GX2 WATER BLOCK
http://xtreview.com/addcomment-id- [...] block.html
The German company innovatek, known for its water-blocks, already placed the description of water-block for two-chip video card geForce 9800 GX2. The special features of water-block is its two layout and working surfaces, which make contact with the video chip areas, memory microcircuits and some power elements.
http://maxupload.com/img/578B54BC.jpg
This water-block is intended for the installation in video card GeForce 9800 GX2 from EVGA (black pearl).
http://maxupload.com/img/EFD00C32.jpg
Both water Carbines was developed with 180 degrees relative to each other.
http://maxupload.com/img/A3CE5BD2.jpg
The cost of this water-block is equal to 197 Euro. It is expensive, but video card also will cost not less than $599.
Message edited by jc98 on 03-13-2008 at 09:24:57 PM
Sponsored Links
ya this is what evga uses on the factory stuff
same with the new 790i black pearl
------------------------------ http://i63.photobucket.com/albums/h138/4rothrocks/WarpedSystemsAnimation-1.jpg
Reply to dragonsprayer
- 0 +
Rest assured only those with more money than sense will be purchashing both of these.
Those of us who prefer not to watercool can do away with our central heating systems and instead leave our PC's side panel off during 3D Applications.... hell why not let the kids toast marshmellows too.
Reply to dev1se
- 0 +
You know it keeps both those cores individually cooler then a 8800GT cooler, right? I don't get the problem. As far as i know it doesn't even create as much heat as R600 did.
------------------------------ Na na na na na na na na HATMAN!
Reply to Hatman
- 0 +
I should hope it does, considering the size of it! But to be charging so much for the card, plus the watercooling... not worth the money or invalidation of your warranty in my opinion.
Reply to dev1se
There are 417 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
