News
Cray To Build An Almost-Petaflop Supercomputer For The University Of Tennessee
<img src="file:///C:/Users/Wolfgang/AppData/Local/Temp/moz-screenshot-2. Read more
IDF Taipei: Intel Releases DTS Specs For All Core 2 Processors (Updated)
It has been a long time coming, but the pieces are slowly falling into place. Intel has now released the official Tjunction Max value for all 65nm and 45nm Core 2 processors at the Intel Developer Forum in Taipei... Read more
Tyan launches Intel Xeon 5000-series based server lineup
Tyan Computer launched a lineup of servers based on the dual-core Intel Xeon 5000-series processors - the Tempest i5000PX (S5380), which targets the high-end sector and the entry-level and mid-range series, the Tempest i5000VS (S5372) and Tempest i5000VF (S5370). Read more
Hybrid Semiconductor Material Found For High-temps
Imagine a CPU that can withstand 200C temperatures without damage. Such a thing may be possible with a new line of hybrid zero thermal expansion materials which are proving suitable for semiconductor use, as well as a new class of positive, negative or zero thermal expansion materials. Heat may soon be our enemy no longer. Read more
Latest Reviews & Articles
Cryostasis: From Russia, With An Appetite For Fast Hardware
We recently had the chance to play a bit of Cryostasis, the latest title supporting Nvidia's PhysX technology. In fact, we played the game on five different hardware configurations. Want to play this one? We'll tell you what you need in order to enjoy it. Read more
Hard Drives, Yesterday And Today: From 500 GB To 1.5 TB
Hard drive capacities have increased in large increments over the last few years, while trends indicate reduced spindle speeds of 5,400 RPM instead of 7,200. We looked at three generations of Samsung hard drives to analyze the performance ramifications. Read more
Best Graphics Cards For The Money: June '09
This month, ATI's new Radeon HD 4770 is missing in action, since online stores are not only unable to keep it in stock, but also de-listing it completely. With violent movements in pricing, though, it'd have been taken off the recommended list anyway. Read more
Editor's Corner: Nvidia’s Ion Revisited, 7.1 Ch. LPCM Fixed
Nvidia's Ion for the do-it-yourselfer launched last month in the form of Zotac's mini-ITX motherboard. Though sexy in principle, the platform had some teething pains right out of the gate. Chris Angelini revisits those issues and uses Ion as a real HTPC. Read more
All the Reviews & Articles
Tom's Hardware > Forum > CPU & Components > CPUs > CPU Temp Help!
CPU Temp Help!
Hey guys,
I just purchased a gateway p-6831fx and this is my first windows laptop.
Im concerned with a few things just wondering if anyone can help me.
I have been noticing that my temperature readout from Everest is really wierd......
If I am playing a game (like Unreal 3) and the power is not plugged in it is showing the temp at this
CPU: 98 c
CORE 1: 56c
CORE 2: 57c
no I am not making that 98c figure up......thats what it says and I have confirmed with cpud and everest both show that same readout..
now here is something else
If I am playing the same game and have the power plugged in it shows this:
CPU: 60c
CORE 1: 58c
CORE 2: 59c
normal.....
also been noticing when power not plugged in it is showing a lower CPU speed at 1.5 GHz
when power plugged in showing 2.2 GHz (my cpu is a T7500 2.2GHz intel core 2 duo)
Does anyone know why these two things are happening....
Thanks for your time!!
Sponsored Links
Please read the owners manual.
------------------------------ Doctor Hooter
Boobs Boobs Boobs...who loves boobs?...I do I do
Reply to zpyrd
I have already done that......
that was of no help at all
Reply to atst2000
- 0 +
When you run on battery speedstep enables. This happens to extend battery life.
I assume you are running Vista.
Right click on the desktop.
Click on Personalize
Click on Screen Saver
Click on Change Power Settings
Select the Power Plan you would like to use.
Click on Change Plan Settings for extended options.
Mobile processors have a higher thermal margin than there desktop counterparts. Anything below 60C is fine.
Your notebook probably came with thermal option software to control the heat sink fan for the processor, chipset and gpu. It will have options to control fan speed and the temperature when the fan starts.
Check to see if SpeedFan is supported by your notebook.
http://www.almico.com/speedfan.php
Reply to zpyrd
ok check the settings but what am I supposed to do after I get into these settings
what am I supposed to change?
Reply to atst2000
Something weird going on there. First off if SpeedStep was active while on battery, your temps should be lower than when you are plugged in. This is due to SpeedStep lowering Vcore and multiplier (and thus the core clock). Also notice that your core temperatures are nearly identical, but the CPU temp is different. I have never seen the CPU temp rise without a corresponding temp rise on the core temps. Since we are talking about a C2D here, the CPU temp is derived from a temperature sensor inside the heatspreader approximately in the center of the die. The core temp sensors (DTS) are in the core's themselves. Typically core temps will read higher than the CPU temperature. That said, the CPU temperature could be inaccurate due to poor calibration tables in the BIOS. As for DTS, there has been much discussion on how inaccurate these can be due to improperly assumed Tj max. Even with all that said, you should see a corresponding change in your core temps with a change in your CPU temp.
So to paraphrase all this:
1. The behavior on battery seems counter-intuitive when compared to it's behavior on battery. Your temps should be higher on mains.
2. Your core temps don't seem to be changing when your CPU temp does.
What do your temps read while idle? I would be interested to see whether your core temps are lower than ~58C when your laptop is idle.
------------------------------ Don't go away mad, just go away!
Reply to techgeek
set everything in bios to defaults, go into power management in windows and set everything to power saver, and use a secondary temp monitor to verify readings. Use can of air to clean out heatsink ports. run prime 95 to put a real load on processor and see what it does. Do you hear the fan spin like crazy? if not - order a replacement. relatively easy to install - just unscrew the keyboard, pop it out and have a look.
------------------------------ If you don't know what OS/2 is, you don't understand.
Reply to rockbyter
- 0 +
1. He just got the computer I doubt there is any dust in the heatsink.
2. He is using Everest, that is a secondary temp monitor.
3. He doesn't need to run Prime his CPU temp is almost double his core temps.
4. It's Brand new he should not be disassembling it and voiding his warranty.
Reply to Zorg
atst2000, your laptop is functioning properly:
(1) Mobile Core 2 processors do not have Integrated Heat Spreaders; desktop Core 2 processors do.
(2) Mobile Core 2 processors do not use a CPU Case Thermal Diode (Tcase); desktop Core 2 processors do.
(3) Mobile Core 2 processors have documented values for Tjunction Max; desktop Core 2 processors do not.
(4) All four T7500 Spec #'s (SLA44 - E1, SLA3N - E1, SLADM - G0, SLAF8 - G0) are Tjunction Max 100c; http://processorfinder.intel.com/L [...] =&OrdCode=
(5) Everest is reading a "phantom" CPU value similar to SpeedFan "Aux 127". Ignore it or instead use Core Temp.
Comp :sol:
Message edited by CompuTronix on 03-31-2008 at 12:15:48 PM
------------------------------ i7 920 C0 @ 4.1 | Vcore Load 1.360
67c CPU & 72c Core @ 22c Ambient
Xigmatek HDT-SD964 | Push-Pull Fans
Core i7 and Core 2 Temperature Guide --> http://www.tomshardware.com/forum/ [...] ture-guide
Reply to CompuTronix
Thanks for all your replies guys!
well my idle temps are this:
CPU: 42c
CORE 1: 40c
CORE 2: 41c
Its really odd that it would read 98c while playing the game and running on battery power but the other cores are both reading 58c
not sure if its sensor error or what....
oh yeah my bios sucks I cant change any type of voltage settings or anything just lets me change boot settings and time/date...
Ive never seen anything like it but oh well
Anyone have any info on the cpu flucutating I saw that while playing unreal 3 that the max I could run the cpu at 1533 GHz while running the game but when power is plugged in it was showing 2.2 GHz (my cpu is 2.2 GHz) i know about speedstep but shouldnt it still run at full specs for the cpu while playing the game just on the battery?
Thanks!
Reply to atst2000
Your questions have already been answered.
The answers from above professions are good. Other than above professions answer for you, I also suggest you to use Speed fan to check if your Everest with problem and check with your Laptop manufacturer to see if your laptop battery in any recall plan.
Reply to Crazy-PC
There are 873 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
