Closed Solved
Hp pavilion dv9700 screen problem
Hello,
I have an hp pavilion dv9700 which is running windows vista, I can see everything on the screen but I have lines running through the screen, which comes and goes (the screen gets blurry), what should I do or where do you think the problem lies?
5 answers Last reply Best Answer
More about pavilion dv9700 screen problem
  1. Lioness4Lion said:
    Hello,
    Try a different monitor, or take this monitor to different computer, will let you know if monitor is at fault.
    Connections secure ? Graphics card dusty ?
  2. Just to be clear this is a laptop, not a desktop
  3. Best answer
    Sorry about that - I usually look the model up, but didn't this time. That'll teach me !
    Might check the connection from screen to mobo to see if loose.
  4. Best answer selected by Lioness4Lion.
  5. This topic has been closed by Nikorr
Windows Vista HP Pavilion
