Tom's Hardware Forums » Homebuilt Systems » New System Build » Final parts list. What do you think?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Final parts list. What do you think?
Profile: newbie
More Information
CPU - Intel E2160
PSU - Corsair vx 550w
HDD - WD 320gb
RAM - G.Skill 2x1 ddr2 800
MOBO -  GIGABYTE GA-P35-DS3L
CASE -  Cooler Master Elite 330 RC
GPU - MSI Geforce 8400gs - I know this is very cheap. But it will have to do for now. I will definately be upgrading this in the future. Its only $25 w/ $10 mir.
I will be buying these parts very soon from newegg. So please let me know how it looks.
Related Pr oduct
Your Local Canadian
Profile: enthusiast
More Information
so you're going for low-end budget gaming/workstation type computer?
If so, those parts will do you fine, I dont see any issues with them.
Intel C2D E8400 OC @ 4.00GHz.--TRUE 120 W/ Scythe S-Flex 28.0dB.--EVGA 8800GTS 512MB.--ASUS Maximus Formula X38 (0907).--Crucial Ballistix 4x1GB DDR2 4-4-4-12 @ 890Mhz.--WD 150gb Raptor.--Corsair 620HX Modular PSU.--Antec P182 Case.-- Vista x64.
Work smarter, not harder!!
Profile: Honorary Poster
More Information
You might want to consider this PSU/Case combo for $115 - $30 MIR = $85!! Not bad for a 34A on the 12V rail PSU!!
ANTEC Sonata III Mini Case Retail
http://www.zipzoomfly.com/jsp/Prod [...] e=10005323
The rest of it looks okay. What is your budget for this build? Can you transfer over any parts from another build?
PSU Tiers
GPU Power usage
8800gtx/380w PSU!
s939 x2 4200/7900gs/2gb
EE, '80, MD, '84, ret '07
Profile: member
More Information
your choices are good ones for OCing. toss in an aftermarket CPU cooler, read the OCing guide, and get a free performance upgrade.
what are the timings on that GSkill RAM? look for 4-4-4-12. Corsair has some cheap RAM with 4-4-4-12 timings.
listen to lunyone if you are on a budget - the case/PSU he mentions is a good deal since the PSU that comes with it is an Antec Earthwatt 500 which is tier 1 (or 2?).
also, don't forget you will need an optical drive if you plan on installing any software ;)
PS HERE is a link to help you select a CPU cooler if you think OCing is in your future. the best one on the list is $39 i think. if you buy a CPU cooler, don't forget to buy some mx-2 thermal compound ($6) which I've been reading reviews on that say it is better than arctic silver 5.
Message edited by HamRadio on 03-05-2008 at 10:19:50 AM
Add a reply
Google Ads
Related Content
