Tom's Hardware > Forum > Storage > Optical Media > Why have more than one all purpose read write cd/dvd drive?
Forum Storage : Optical Media - Why have more than one all purpose read write cd/dvd drive?
I have one LG 22X Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive on my system.
In configurator builds you are offered a second drive as an option.
Also in packaged systems (i'm smart enough to stay away from those) they package 2 drives.
I see the need for only one all purpose read write cd/dvd drive.
Is there any reason or application need to have 2 drives on your system?
Sponsored Links
The only real main reason is for easy disk copying. There's probably a few other reasons, but I don't really see the need. I have a single drive, and it's all I ever seem to need.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Just ease of access really, though if you use daemon tools to rip your favourite games (that you own) then you can dispense with most dvds alltogether.
Reply to spanner_razor
- 0 +
Its not a necessity...
but at some rare times, i've had an open dvd (not finalized) and needed to get a file or install something using the second drive. Now with home networks and thumbdrives it really is just a convenience thing
Reply to bc4
Not all drives are created equal. Some burn or read better than others. LG is pretty marginal all-around, whereas Pioneer and Samsung are a bit better at both tasks.
Some of us keep multi drives around, just in case we come across troublesome discs.
As stated already, it is helpful for duplication too. (For some of us, small-number duplication is part of our job.)
Message edited by lordsmurf on 04-28-2009 at 08:03:08 AM
------------------------------ DVD Burning Problems? Be sure you're using quality blank DVDs!
Visit http://nomorecoasters.com for help on choosing the best discs.
Reply to lordsmurf
Optical drives is one of the most under-utilize hardware on the PC. For most cases one is sufficient. It does nothing most of the time. I have an LG drive that can read/write from Blue-Ray to the Old CD-Disc. Thats all i need.
------------------------------ Q6600: Maximus Formula: Zalman 9700LED8GByte: Crucial Ballistics 4-4-4-12: PC6400; Vista Ultimate-64BFG XOC 4890; Disp: 70 Inch HDTV: Hauppage 2250 HDTV Tuner1.4TByte: 2x750Gbyte; RAID0; Case: Antec 900: PS:Antec Quatro 850
Reply to leon2006
There are 562 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
