Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > ..::`.'Power Supply Question'.`::..
I have a HP m7580 Pavalion.. I have a noisy fan and i want to get rid of it also because my soon to be bought Nvidia 9600 GT wont support a 300 Watt psu.. I want to know which one is recommended for that certain card and how to know if it will fit my case
Thank you in advanced
Sponsored Links
1. You have 2GB 533 MHz ddr2 ???--Bottle neck---> 2GB 800ddr2 ( see mobo support )
2. ANY GOOD axt 430+ hi-Q with 80 Plus logo (A computer power supply that is more than 80% efficient )
http://www.newegg.com/Product/Prod [...] 6817371006
Reply to JPain
^Agreed on the RAM.
Get a PSU listed in the top tires here:
http://www.xtremesystems.org/forum [...] p?t=108088
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
ohh ty but i still want to know how i can see if the psu will fit, and can you give me a option thats under 50? :) ty
Reply to caution_sign
Hmm... under $50 is kind of a tough choice. For $20 more you can get this:
http://www.newegg.com/Product/Prod [...] 6817153052
or if you must be under $50:
http://www.newegg.com/Product/Prod [...] 6817256032
^$47. You won't be able to plug in much things in to it due to low Watts (ie. 4+HDDs,etc)
1.Open your HP m7580 Pavalion and have a look and see...
2. 80+ PSU under 50e or £ or $ ??? Under 50$ that will be hard one...
Reply to JPain
i think i'll go with the 70$ thermaltake one then :) but i want to know wy my computer is making so much noise :-/ its clean inside i checked but its extremely loud (Jet plane Stylin') :( is there any way to lower the rotations per second in the meanwhile?
1. Bios settings ok?
2. You can use zalman RS100 to lower your fan speed.... but look temps
Reply to JPain
man - you don't know noisy till you've heard a 2900 XT or pro, now THOSE are jet planes (can hear mine through 2 layers of wall, when on about 70% speed :P)
Reply to spuddyt
Finding a "good" PSU (at least tier-3, preferably 2) for only $50 can be a daunting task, but deals are sometimes available.
Here's an Antec unit (probably a tier-3)
Antec Basiq BP500U ATX12V Version 2.01 500W Power Supply 100 - 240 V UL, CB, CE, CSA, TUV, FCC - $40 after $30 MIR
http://www.newegg.com/Product/Prod [...] 6817371004
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
There are 606 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
