Lan problems after wake from sleep
Solved
Control panel/Network connections/right click local area connection/properties/configure/advanced-scroll down property window to WakeOnLan From PowerOff at the bottom-highlight- then choose disabled/OK
1 answer Last reply
More about problems wake sleep
  1. Hello and welcome to Tom's Hardware Forums.
    You might also benefit from altering the power saving setting for the ethernet adapter.
Configuration Control Panel LAN Connection Windows Vista
