Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Quick question about connecting case fans to motherboard
Forum Motherboards & Memory : General Motherboard - Quick question about connecting case fans to motherboard
I'm right in the middle of my system build and just noticed that the motherboard (Asus P5K-E) has connectors for fans (PWR_FAN, CHA_FAN1 thru CHA_FAN4). I assume this allows me to connect any/all the case fans to the motherboard instead of connecting them directly to the power supply? I searched the forum and everything seems to indicate that's what they are there for, but my 1st build I had the fans connected to the PSU and I want to make sure I don't screw something up. It already took me like an hour to install the CPU and mobo because I had to take the mobo out because I should've installed the CPU and heatsink first (I guessed wrong on the order).
Is the PWR_FAN connector the same as the rest? It's the closest to the top fan and I want to plug it in to that one.
Stupid question, I know, but I'd rather ask the stupid question now then have to buy a new CPU and mobo because I didn't ask. Thanks.
Sponsored Links
Just a last minute check for a yay or nay. I ran out of time last night so I got everything connected but haven't powered up yet.
I have to say, that Q6600 heatsink fan is really a pain to mount.
Reply to zenghost
all fan headers on the mainboard will power the fans no issues... as long as the fans have 3 pin connectors... i have 6 plugged into my P5K-e no probs ;)
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
Thanks, chookman, it's always nice to get confirmation. Everything booted and right now drive is formatting and installing windows XP. I think I'm going to have issues with that heatsink, though, it's really not secure on there. I can just pull it off without any effort. I think I'm definitely going to have to go out and get an aftermarket one.
On the bright side, with all of the fans plugged into the mobo and getting rid of all my IDE devices the case looks a lot cleaner.
Reply to zenghost
Did you make sure that the clips were securely through the otherside of the motherboard, because there is no-way you should be able to just pull them off.
Reply to chookman
Just make sure the fans are not drawing too much power for the connector. Many case fans on the market need more current than the on-board fan headers can supply, and thus risk burning out those circuits.
PWR-FAN can be used for anything, but is intended for the power-supply fan speed connector that some PS's have.
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
This post may help on mounting the CPU cooler (it needs to be done with the MB outside the case): http://www.tomshardware.com/forum/ [...] y#t1184072
Reply to Mondoman
- 0 +
A follow up question. Where does one connect the second case fan on a M3N78 Pro Asus MoBo? There is only one cha fan1 connector. The PSU fan header is used by the PSU and the cpu fan header is used by the CPU fan. Now what?
Is there an adapter to parallel the little three pin header?
TIA
Richard
Reply to dicnic
There are 1095 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
