Tom's Hardware Forums » CPU & Components » Power Supplies, PC Cases & Case Mods » CM 690 - cable routing behind MB mount plate w/ existing cutout?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : CM 690 - cable routing behind MB mount plate w/ existing cutout?
Profile: journeyman
More Information
I have my CM 690, and LOVE IT!  Good looking case, can put fans EVERYWHERE...
BUT, I tried running my PSU cables (Corsair vx550w) through the small cutout by the PSU (which was a pain jamming them in there), but now that I look at the other side of the case behind the MB mounting plate, there's almost no room to run the cables.
The part of the mounting plate that I would run the cables around to (the side nearest the front of the case) has a lip that is VERY close to the panel when you put that side back on.  What the heck? Am I missing something? How the heck can I run my cables behind that, I can't even squeeze my pinky finger between the mounting plate and the side panel (once installed) because of that lip.
I guess I can cut part of the lip away, but hate chopping up a brand new case. Maybe I'm missing something. What do you other 690 owners do?  :)
Thanks!
Related Pr oduct
Profile: enthusiast
More Information
in my 690, i put all the excess cables behind the motherboard tray and taped them in.
http://i201.photobucket.com/albums/aa129/xringx/2x140mmfansattopofcase006-1.jpg
Q6600@ 3.60GHz(9x400) Abit IX38QuadGT,TRUE 120 Lapped,Vista Ultimate 64bit,Gigabyte HD 3870 OC'd to 860/2250 w/ Zalman Fan,4x1GB Crucial Ballistix (4,4,4,12),CM690 w/ 5x140m 3x120m fans,Idle 38c load 55c-Corsair HX620w
Profile: enthusiast
More Information
oh, forgot to address your issue.  I found plenty of room at the very bottom.  The lip ends
Profile: journeyman
More Information
Thanks, brother!  Case looks good man!  I wish I'd have gotten the extra fan for the bottom of the case for additional intake.
Message edited by MichaelPBF L on 04-04-2008 at 01:31:05 AM
Profile: enthusiast
More Information
A quick cut before you put everything in will come handy, especially in fiture installations with bigger, longer PSUs. I have the same case and love it, it is very quiet, cool and roomy!. Wish i had made the cut i am talking about though before i put everything in there.. oh well... on my next upgrade, hehe..
With great power comes great responsibility
Profile: newbie
More Information
I'm not sure what you meant by "a quick cut". I've got a 690 on the way, with a fan for the bottom. I have a pretty big pcp&c silencer 750. Is there a modification I should make before I put it together?
Profile: enthusiast
More Information
no, you dont have to mod the case to route the cables..
Add a reply
Google Ads
