Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > HELP! NEW system, 3 diff BSODs
Forum Motherboards & Memory : General Motherboard - HELP! NEW system, 3 diff BSODs
after having trouble getting my new build working, i finnally got it going. everything works great except a BSOD happening about 30mins to 1 hour into each gaming session. i am using ms debugger and getting 3 different problems.
the first pointed to a file called:
ntkrnlmp.exe ( nt!KiReadyThread+2df )
the second said the problem was a memory corruption.
the third said it was nv4_disp.dll.
i think the prob is my motherboad becuz after i recieved a DOA giga p35, stupid me just couldnt wait to get it runnign so i bought an MSI p31 from a local shop, not knowing it was a POS that i found out about after reading various reviews. could this be the problem?
here is my full system specs:
MSI p31 mobo
Intel q6600
Geforce 8800GT
BFG 550w psu
Gskill 2x1gb RAM
windows xp sp2
Sponsored Links
MSI p31 mobo
Intel q6600
Geforce 8800GT
BFG 550w psu
Gskill 2x1gb RAM
windows xp sp2
well now,,assuming ?? that all your connections [hardware] are correct,,are they??, because your first error looks like a kernel error,and your third error looks like a video [nvidia]error,,usually when windoze gives multiple errors,it could be either a bad install or improperly connected,or malfunctioning hardware,,if you are sure that all is well,,then RMA the mobo ASAP,if you can get a hold of some "NIX" type of os that boots from a cd/dvd,and if it acts up,then see above,,on the other hand if you can exchange that p31 for a intel p35 chipset,,i know,you had one die on you,if it was new why not just get a replacement??
remember where computers are concerned,,,,,"make haste slowly"good luck.:)
ps,,is the Gskill on the QVL for that mobo??? i have the QVL for the gigabyte p35 and ,,guess what???,,no Gskill...
**qualified vendors list**
Reply to dokk2
MSI = POS, full stop.
3 DOA Gigabytes? i doubt that - check that everything is assembled correctly, and in good health - memory and hdd, cables, psu etc
------------------------------ Q6600@3510/1560 + TT BigTyphoon+Mod
8gb Kingston 800mhz
Gigabyte EP35-DS3P
XFX 8800GT/512
Reply to apache_lives
There are 1150 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
