HARD DRIVE 1: Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA-300 Hard Drive - OEM
@NEWEGG $104.99
HARD DRIVE 2: SAMSUNG Spinpoint F1 HD753LJ 750GB 7200 RPM 32MB Cache SATA-300 Hard Drive - OEM
@NEWEGG $149.99
HARD DRIVE 3: SAMSUNG Spinpoint F1 HD753LJ 750GB 7200 RPM 32MB Cache SATA-300 Hard Drive - OEM
@NEWEGG $149.99
SOUND CARD: Included in Motherboard
OPTICAL DRIVE 1: SAMSUNG Black 20X DVD+R 8X DVD+RW 16X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe - OEM
@NEWEGG $33.99
CASE: COOLER MASTER cosmosS RC-1100-KKN1-GP Black Aluminum ATX Full Tower Computer Case - Retail
@NEWEGG $249.99
POWER SUPPLY: COOLER MASTER Real Power Pro RS-850-EMBA ATX12V / EPS12V 850W Power Supply 100 - 240 V CE, cUL, TUV, NEMKO, BSMI, FCC - Retail
@NEWEGG $199.99
MONITOR: SAMSUNG 245BW Black 24" 5ms DVI Widescreen LCD Monitor with Height Adjustment 400 cd/m2 1000:1 (DC 3000:1) - Retail
@NEWEGG $469.99
TOTAL COST = US$2,365.88 n.b. the prices of course are subject to change depending on the store and date the product is ordered from.
Hard drive 2 and 3 will be for a RAID setup. I'm looking to add a Blu-ray burner/player when those become more mainstream (cost wise) than they are now. Also, a 2nd graphics card for SLI, if not CF, depending on purchase for 1st gfx; (optional total graphics upgrade when the next generation cards come into play).
I'll be installing Vista but I'm wondering what is/are the hype/benefit(s) of 64 versus 32bit, and if 64 bit, would it be better to go with the 8 GB RAM than the current 4 GB I'm looking at. Finally, Monitor help for a 1920x1200 resolution would b a great help. N e further advice is greatly appreciate.
... Also, a 2nd graphics card for SLI, if not CF, depending on purchase for 1st gfx; (optional total graphics upgrade when the next generation cards come into play).
I'll be installing Vista but I'm wondering what is/are the hype/benefit(s) of 64 versus 32bit, and if 64 bit, would it be better to go with the 8 GB RAM than the current 4 GB I'm looking at. Thanks for the help.
I went with 1 larger card versus SLI.
I went Vista 64 Ultimate with 4 gigs (2 x 2) DDR2 800 and have been very happy. Some will say XP and some will say Vista 64 with 8 Gigs. In your price range, I would consider Vista 64 Ultimate with 8 gigs. The Vista versus XP debate has raged here for awhile. XP and Vista 32 bit can only use 3.5 gigs of ram versus vista 64 bit being able to use 8 gigs.
If you want to overclock you'll need a better cooler too. I have the Freezer 7 Pro, but if your budjet is $2400, you might want to look at a Thermalright Ultra-120 with some nice fans.
ImajorI, thanks alot for the power supply rating heads up.
Reason I put the 1GB Crucial RAM was due to the lower timing of 4-4-4-12. I couldn't find 4-4-4-12 timing in the 2GB versions. However, is the 5-5-5-15 timing for the ram not noticeable when compared to the 4-4-4-12?
The rig will be overclocked (looking at 3.6 - 4 GHz); at this range it looks like a new processor cooler is in order. The rig will be used for gaming, encoding movies/videos. CAD work will also be done on the rig.
