Tom's Hardware Forums » Homebuilt Systems » New System Build » Final system - any thoughts?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Final system - any thoughts?
Get out of here...and take your fail with you.
Profile: member
I finally decided on a build.
Let me know if you have any qualms, recommendations, or thoughts about it.
CPU: Intel Core 2 Quad Q6600 G0 stepping - Overclocked to 3.2 Ghz - 400 Mhz x 8.0
Motherboard: Gigabyte P35-DS3L Intel P35 chipset motherboard
Memory: G. Skill 2 x 1gb DDR2-800 - CL 5-5-5-15
Video Card: GeForce 9800 series (I am waiting for this one)
Case: Cooler Master Centurion 5 series
Power Supply: XClio Greatpower 500w PSU - Three 12v rails, modular
Hard Drive: Western Digital 160 GB 7200 RPM 8mb cache
Thanks for your comments in forward!
Intel Core 2 Quad Q6600 G0 @ 2.68 GHz/1.12v (Stock cooling p'wns!) - Gigabyte GA-G31M-S2L - 4 GB A-Data DDR2 800 @ 897 MHz - GeForce 8800 GS (EVGA 384-P3-N851-AR) @ 700/1745/2056 - ASUS Vento mini tower - Seagate 250 GB 7200.10 hdd - Vista Ultimate x64
Related Pr oduct
Your Local Canadian
Profile: enthusiast
More Information
good, great, grand.
Intel C2D E8400 OC @ 3.6GHz.--TRUE 120 W/ Scythe S-Flex 28.0dB.--EVGA 8800GTS 512MB.--ASUS Maximus Formula X38 (0907).--Crucial Ballistix 2x1GB DDR2 4-4-4-12 @ 800Mhz.--WD 150gb Raptor.--Corsair 620HX Modular PSU.--Antec P182 Case.-- Vista 32bit.
Gosh, i love ATI
Profile: addict
More Information
be careful with the nVidia 9 series... apparently they aren't all they're cracked up to be
Profile: member
More Information
get 2x2 gb memory even if you are going 32 bit
9800 series wont be out intil may/june/july except for the 9800 gx2 which is basically just two 8800gts 512mb g92 in sli through one pci-e.
if you get a evga 8800 gts 512mb g92 now you can use the step up plan to get the "real" 9800 cards within 3 months
i dont know about the power supply, but never buy the cheapest one you can find (link?)
Profile: member
The 9600 GT outperforms a Radeon 3870 when AA and AF are turned up.
And that is just the mid-range card.
Profile: old hand
More Information
Get this power supply;
http://www.buy.com/prod/corsair-52 [...] 70716.html
Here's a very good deal on 2X1 Ballistix, a little better than the G.Skill;
http://www.newegg.com/Product/Prod [...] 6820146565
Opinions are like asses,everybody has one.
Profile: member
I am on a really tight budget with this system.
I think the G. Skill memory and the XClio supply will do fine. The XClio is a tier-2 according to Tom, and the memory has around 1000 reviews on Newegg. All 5-egg.
Sniper
Profile: Forum Veteran
More Information
Looks good to me. You might want to take a look in to the Crucial Ballastix. 2*1GB for $30 after MIR:
http://www.newegg.com/Product/Prod [...] (PC2+6400)
btw, you can take the newegg reviews with only a grain of salt.
E2180 @3.2Ghz + P35DS3L +8400GS (700/475 OC)
http://farm4.static.flickr.com/3268/2588429538_b3c41b29c3.jpg
Do not eat the styrofoam
Profile: Forum Fixture
More Information
Sounds good.
Don't buy the case and PSU until you see the 9800 card released and you know for sure the case is big enough and the PSU is powerful enough. Also, before you buy the 9800, see what ATI has to offer at that time too. They use 55 nm technology already, while nVidia is still at 65.
Add a SH-S203B burner.
Consider the GA-P35-DS3R instead of DS3L if you intend to use RAID or add lots of disks.
In a world without walls and fences, who needs windows and gates?
Profile: member
I think the case will be big enough no matter what...
It fits an 8800 G80 with room to spare.
As for the PSU, it is SLI-certified, so I am good for any single card that comes out. I was planning on just a 9800 GT or perhaps even a 9600 GT, both of which should suck less power than any 8800 series card.
This PSU is also on Tier-2, like I stated before. It has 3 - 12v rails, at 18A, 18A and 16A respectively.
I will be watching the video card market like a hawk. If ATI comes out with something better for ~$200, I will buy that.
Profile: member
More Information
when are you  building this?
Add a reply
Google Ads
