Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > SOMEONE GIVE ME ADVICE WHICH CASE IS BETTER?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - SOMEONE GIVE ME ADVICE WHICH CASE IS BETTER?
Antec 900 or Antec P182?its purpose is for air cooled heatsink.so the watercooling hole on the p182 doesnt really matter to me.
Sponsored Links
Depends on your purpose, the Antec P-182 looks nicer, is more quiet, and has much better cable management, however, the Antec 900 cools slightly better, and looks better, depending on taste. It really does not matter what case you use, both will work fine with air cooled heatsinks.
Reply to The_Blood_Raven
^^ yes... it's all a matter of personal taste. I love my Antec 900 and mod the heck out of it!
Message edited by hughyhunter on 04-08-2008 at 04:00:00 AM
------------------------------ EVGA 780i--Intel E8400@4.05Ghz--TRUE--EVGA 8800GT SLI--2X2GB OCZ reaper @800mhz 4-4-4-15-1T--Antec 900--PCPC 750 silencer--150 raptorX!
Reply to hughyhunter
from the fan configuration available on both case the antec 900 have better cooling there can be install with 1 more fan and the top fan is bigger hence more air flow.
and one curious question isnt the antec 900 a full tower case and the p182 is a midi tower suppose to be smaller?
Reply to iluvgillgill
Antec 900 is mid tower
- 0 +
Today I just finished to buy my NZXT lexa blackline and its a beatiful case, good ventilation and everything.
I love it :D
Reply to tato999
- 0 +
IF UR GONNA SHOUT AT PPL DONT FORGET TO SAY PLS.
------------------------------ Q6600 B3 3.0Ghz @ 1.125v
4850
P5B-D
8Gb 800mhz
Reply to mrmez
antec 900...
I love the huggggggggggggggge exhaust fannn
Reply to wah_gwan
The P-182 cools almost as well as the Antec 900, thanks to its superior cable management and layout. It all comes down to personal taste, there is nothing that makes either absolutely better.
- 0 +
Except the fact that the 900 is quite loud and the P182 is quiet to silent.
Message edited by Andrius on 04-08-2008 at 01:37:37 PM
Reply to Andrius
but i think the antec 900 is better because the side panel is see through.no point make the cabling nice and neat when no one (include me) can see whats inside.thanks guy i think i will get the antec 900.
thanks for all the help guys!
PLEASE!!!!!!!mrmez!!!:p
Quote :
Not actually true - if you have cables all over your case, they'll obstruct your airflow, and if it's really bad they can get snagged on fans and such. I'm not advocating either case, just pointing that out :P
EDIT: Oh and if you need to upgrade or otherwise fiddle with your components, your life will be made much easier if you don't have a mass of cables in the way.
Message edited by Demonic Goldfish on 04-08-2008 at 08:46:46 PM
Reply to Demonic Goldfish
- 0 +
Antec 900 also has water cooling holes.
I bought one for the hopefully better cooling. And although I am a proponent for neat cabling layouts, I regard the side window of a case as a useless feature.
Reply to jsc
Check out this thread http://www.xtremesystems.org/forum [...] p?t=126395 It's easy to make the 900 cable managable.
There are 1060 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
